moving codefrom GT740 to K40c
I met a problem that when I moved my project from gt740 to k40c, the result of the computation was different , and the most serious thing is that the result of k40c was wrong;
I’m using VS2010, the version of CUDA Toolkit is 7.5;
What and how can I do to solve this problem?
I’ll appreciate so much if someone can help me to solve this;
Probably you should start debugging.
Pretend that you never had a gt740, and this is the first time you are running a code that you have just written, but you’re getting the wrong result.
Hi txbob,
Thank you, after debugging, the code on K40c works right.
