Dear NVIDIA TEAMS
請問一下MP8856GQE I2C 位址是否在公板上可以控制VCC_PD 的參數?
如果沒有使用這顆MP8856GQE IC 對於TYPE C 是否會有影響? 沒有連CVM I2C function, 直接輸出VCC_PD 這樣做是否也可以!!
謝謝
Dear NVIDIA TEAMS
謝謝
NVIDIA provides the Jetson Thor Series USB Type-C PD Controller (CYPD8225) Firmware on the Jetson Download Center that is tightly coupled to the MP8856 PD regulator. Switching to a different PD regulator breaks functionality with the provided firmware, so you would have to work with Infineon to customize CYPD8225 firmware accordingly. Note that the CYPD8225 controls the I2C bus to the MP8856, not a separate I2C bus from the Thor SoC or another source on the module.
Completely removing MP8856 without replacing it would break the power delivery functionality of the USB-C ports. The CYPD8225 negotiates with the device connected to the USB-C port to determine the voltage the MP8856 outputs on VCC_PD. We highly recommend keeping the MP8856 PD regulator.
Dear Chris
Thank you so much for this highly detailed and professional analysis. Pointing out the tight coupling between the CYPD8225 firmware and the MP8856, as well as the independent I2C bus architecture, is extremely crucial for us. This timely insight helps us avoid potential firmware customization risks and significant R&D overhead. We will follow your recommendation and keep the original MP8856 design for our project.
Dear Chirs
Carrier board 目前要用power Button 開機,Button MCU 有燒錄官網FW(Jetson_Thor_DevKit_Power_Button_Firmware_v1.0) ,目前量到P0_0 pin2 有button low to high,在P1_6 pin8 沒有任何動作,請問這跟pin 8 前一級需要看哪一根pin 腳位的狀態? 謝謝
Dear Chris
目前power button 沒有問題了。在請教VIN_PWR_BAD_N 這個訊號 在TPS3840DL20DBV pin 1 (RST*),pin 2 (input) 電壓28V 沒有掉電,如何跟power button down 拉Low ?
Thanks~
Translation: "The power button issue has been resolved. I’d like to ask about the VIN_PWR_BAD_N signal on the TPS3840DL20DBV:
How can [this signal] pull Power Button Down to LOW?"
(Please correct if needed)
What voltage level do you see on VIN_PWR_BAD_N? Have you verified your design with a scope against Figure 5-2 Power-On Sequence in the Jetson Thor Series Modules Interface Design Guide?
Did you ground pin J62 of the module connector? The module will not function properly if the pin is floating.
Dear Chris
VIN_PWR_BAD_N : 4.1V ,J62 pull down , GPIO56_BOOT_CHAIN_SEL pull down , 可以開機進系統,謝謝。
再請問一下,
HDMI CEC 會影響到HDMI的顯示?
TYPEC PI3DPX1205A1ZLBEX 這一顆IC 會偵測有插type C device之後透過I2C 溝通後 ,去打開MP5046 的VCC_PD 的電壓? 現在插Typec Device 沒有電壓
I don’t fully understand the question. HDMI CEC would not cause the HDMI interface itself to not work. Is that what you meant?
The CYPD8225 PD controller handles the plug detection over the CC lines and the PD controller also enables the VBUS to the USB-C connector as needed after it determines its role with the connected device. Did you flash the Jetson Thor Series USB Type-C PD Controller (CYPD8225) Firmware?
Dear Chris
Yes , thanks. HDMI CEC affect HDMI display ,this is what i mean .
I am flash mtb-example-ccg8d-notebook-dualapp-tbt.hex.
Thanks for your support.
Dear Chirs
CC lines sometimes the connection is intermittent.
CC lines differential trace routing . CC line impendance 10 ohm . CC line trace width 10mils .
Thanks~
Please contact the Infineon support team for issues on the CYPD8225. Since the CC signals go from the CYPD8225 to the USB-C connector, they are outside of the scope of what can be supported on the Jetson forum.
