I’m trying to compile OpenMPI 1.8.4 or MPICH 3.1.3 or 3.1.4 on OS X 10.10.3 with the PGI 15.4 suite but am receiving the following on configuration.
$ ./configure --prefix=
== Configuring Open MPI*** Startup tests
checking build system type… x86_64-apple-darwin14.3.0
checking host system type… x86_64-apple-darwin14.3.0
checking target system type… x86_64-apple-darwin14.3.0
checking for gcc… pgcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… configure: error: in/Users/mrilee/src/openmpi/openmpi-1.8.4': configure: error: cannot run C compiled programs. If you meant to cross compile, use
–host’.
See `config.log’ for more details
And config.log shows things going bad starting with
configure:5989: checking whether we are cross compiling
configure:5997: pgcc -o conftest conftest.c >&5
PGC-S-0040-Illegal use of symbol, __BEGIN_DECLS (/usr/include/stdio.h: 156)
PGC-S-0035-Syntax error: Recovery attempted by replacing identifier __BEGIN_DECLS by ‘;’ (/usr/include/stdio.h: 230)
PGC-W-0156-Type not specified, ‘int’ assumed (/usr/include/stdio.h: 230)
PGC-S-0036-Syntax error: Recovery attempted by inserting keyword typeof before ‘(’ (/usr/include/stdio.h: 242)
PGC-S-0138-Missing identifier for declarator in function prototype definition (/usr/include/stdio.h: 242)
PGC-S-0040-Illegal use of symbol, __DARWIN_ALIAS_STARTING (/usr/include/stdio.h: 242)
PGC-S-0033-Missing declarator for dummy argument (/usr/include/stdio.h: 242)
PGC-S-0035-Syntax error: Recovery attempted by replacing typedef id __printflike by ‘=’ (/usr/include/stdio.h: 244)
and so on… Setting CPP=cpp doesn’t help.
Any way around or through this?
