Was trying to compile an MPI C code and got the error:
pgi-cc-lin64: LICENSE MANAGER PROBLEM: No such feature exists.
I guess this means that we need a special license for MPI C compiling? This surprised me because I thought PGI C was basically gcc or gnu c, or whatever. Before I start lobbying my powers that be for a license upgrade, could someone set me straight on this?
Hi Cablesb,
mpicc is just a wrapper for which ever C compiler you built your MPI library with. If you built it with PGI’s C compiler or are using the MPICH install that accompanies the compilers, then yes you do need a license to use it. However, we inter-operate with gcc, so you are welcome to build your own MPI packages using gcc + PGI Fortran.
Nope. PGI’s C compiler, PGCC, is completely separate from GCC.
While there are reasons to purchase PGCC over GCC, building MPI is not one of them. So if this is all you need a C compiler for, then stick with GCC. If you are looking to develop C code for the GPU, OpenMP, or high performance, then these are the reason to look to PGCC.
