MPS for Jetson AGX Orin
Is MPS (Multi Process Server) not supported for Jetson as of now?
In the latest post I could find it is said no,
AGX Orin support MPS? - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
however in CUDA for Tegra, instruction for using MPS is described.
1. CUDA for Tegra — CUDA for Tegra 12.8 documentation
Could someone confirm the latest status?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Hi @carolyuu ,
I’m also interested in if MPS can be used in Jetson.
In short is it supported now?
Thank you.
Yes, MPS has started to support Jetson from CUDA 12.5.
More information can be found in the below link:
