MPS overhead
Description
I use MPS to allocate 50% GPU to each of the two containers.
And than, if I run python code what use many core in both containers at the concurrent, process slows down.
But if I run it separately, it doesn’t slow down.
Shouldn’t the MPS not be affected by the work performed in other containers because the core is divided?
However, if you run a code that uses a little core at the concurrent, it won’t slow down.
Environment
GPU: T4
Container platform : Kubernetes
my_code.py
ref: Temel metin sınıflandırması  |  TensorFlow Core
import time
import tensorflow as tf
from tensorflow import keras
import numpy as np
start_time = time.time() * 1000
gpus = tf.config.experimental.list_physical_devices('GPU')
if gpus:
  try:
    tf.config.experimental.set_virtual_device_configuration(
        gpus[0],
        [tf.config.experimental.VirtualDeviceConfiguration(memory_limit=1024)])
    logical_gpus = tf.config.experimental.list_logical_devices("GPU")
  except RuntimeError as e:
    print(e)
imdb = keras.datasets.imdb
(train_data, train_labels), (test_data, test_labels) = imdb.load_data(num_words=10000)
word_index = imdb.get_word_index()
word_index = {k:(v+3) for k,v in word_index.items()}
word_index["<PAD>"] = 0
word_index["<START>"] = 1
word_index["<UNK>"] = 2  # unknown
word_index["<UNUSED>"] = 3
reverse_word_index = dict([(value, key) for (key, value) in word_index.items()])
def decode_review(text):
    return ' '.join([reverse_word_index.get(i, '?') for i in text])
decode_review(train_data[0])
train_data = keras.preprocessing.sequence.pad_sequences(train_data,
                                                        value=word_index["<PAD>"],
                                                        padding='post',
                                                        maxlen=256)
test_data = keras.preprocessing.sequence.pad_sequences(test_data,
                                                       padding='post',
                                                       maxlen=256)
vocab_size = 10000
model = keras.Sequential()
model.add(keras.layers.Embedding(vocab_size, 16, input_shape=(None,)))
model.add(keras.layers.GlobalAveragePooling1D())
## I control the gpu core this code
for i in range(50):
  model.add(keras.layers.Dense(1000, activation='swish'))
model.add(keras.layers.Dense(16, activation='relu'))
model.add(keras.layers.Dense(1, activation='sigmoid'))
model.compile(optimizer='adam',
              loss='binary_crossentropy',
              metrics=['accuracy'])
x_val = train_data[:10000]
partial_x_train = train_data[10000:]
y_val = train_labels[:10000]
partial_y_train = train_labels[10000:]
history = model.fit(partial_x_train,
                    partial_y_train,
                    epochs=40,
                    batch_size=512,
                    validation_data=(x_val, y_val),
                    verbose=1)
end_time = time.time() * 1000
end_start = end_time - start_time
print('total time: %d'%(end_start))
Request you to share the model, script, profiler and performance output if not shared already so that we can help you better.
Alternatively, you can try running your model with trtexec command.
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
While measuring the model performance, make sure you consider the latency and throughput of the network inference, excluding the data pre and post-processing overhead.
Please refer below link for more details:
https://docs.nvidia.com/deeplearning/tensorrt/archives/tensorrt-722/best-practices/index.html#measure-performance
https://docs.nvidia.com/deeplearning/tensorrt/best-practices/index.html#model-accuracy
