hi , currently I have a workload automation required a mqtt protocol ( mosquitto server running a local host ), after I check on the forums , the mqtt adaptor deepstream-4.0.1/sources/libs/mqtt_protocol_adaptor at master · Kwull/deepstream-4.0.1 · GitHub is some modification of kafka adaptor , I would like to ask for clarification , is this github links source are real mqtt implementation ? thanks !
thank you for your reply , is this mqtt adaptor working on 5.1 ? as I check the files in the mqtt source , some of it are label with kafka , I think they are rename from “kafka” to mqtt , but are this real mqtt protocol ?
for example this file deepstream-4.0.1/nvds_mqtt_proto.cpp at master · Kwull/deepstream-4.0.1 · GitHub
