I’m trying to implement MQTT in my project but I’m running into a PhysX error (see image below, this also happens for getWakeCounter()
So the general idea is that I want to change the speed of the angular drive of a cylinder. I am working via the docker container deployment, so I installed the Mosquitto broker outside of the docker container (in the Azure server) like so: Installing the Mosquitto MQTT Server to the Raspberry Pi - Pi My Life Up. From the same location I communicate to the receiver like so: mosquitto_pub -h <public_azure_ip_address> -t "/velocity" -m "200"
The receiver is an extension I created in Isaac Sim. Hereby a piece of code that generally shows what I’ve done:
import omni.ext
import omni.usd as usd
import threading
import paho.mqtt.client as mqtt
class MyExtension(omni.ext.IExt):
def __init__(self):
self.host_ip = "<public_azure_ip_address>"
self.port = 1883
self.topic_subscribe = "/velocity"
self.client = mqtt.Client()
self.client.on_connect = self.on_connect
self.client.on_message = self.on_message
self.client.connect(self.host_ip, self.port, 60)
self.client.loop_start()
def on_startup(self, ext_id):
print("[omni.conveyor.modules] MyExtension startup")
def on_shutdown(self):
print("[omni.conveyor.modules] MyExtension shutdown")
self.client.loop_stop()
def on_connect(self, client, userdata, flags, rc):
print("Connected with result code " + str(rc)).
self.client.subscribe(self.topic_subscribe)
def on_message(self, client, userdata, msg):
print("Set speed:" + str(msg.payload))
speed = int(msg.payload)
stage = usd.get_context().get_stage()
joint = stage.GetPrimAtPath('Cylinder/joint')
joint.GetAttribute('drive:angular:physics:targetVelocity').Set(speed)
I also tried placing self.client.loop_start()
in the on_startup
function but that didn’t work either.
Note that the same way of changing speed works when I would simply make a button for it, so my hypothesis is that it has something to do with that the MQTT thread interrupts something in the main Isaac thread (or the other thread? I noticed that Isaac already uses 2 threads by default) that the program doesn’t like as it interrupts something that happens internally.
The confusing thing is that sometimes it does work for a little while, but then it breaks, but I cannot find a pattern in why it suddenly breaks.
Does someone know how to fix/tackle this problem?
