Hello, my nvidia card is not working in a way similar to mentioned in this forum before, but what I tried from suggestions here didn’t help.
When I try open nvidia-settings in terminal - it opens but I see errors in terminal:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:4457): GLib-GObject-CRITICAL **: 14:40:00.081: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 14:40:00.085: PRIME: Requires offloading
** Message: 14:40:00.085: PRIME: is it supported? yes
** Message: 14:40:00.112: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 14:40:00.112: PRIME: on-demand mode: "1"
** Message: 14:40:00.112: PRIME: is "on-demand" mode supported? yes
Port HDMI is not working (so external display/TV not detected)
I have MSI laptop GF75 Thin 10UEK with Ubuntu 21.04
I tried UEFI boot mode without CSM - but ubuntu hangs after booting with just empty desktop/wallpaper image over screen and doesn’t work.
I tried adding pci=realloc to /etc/default/grub & update-grub & reboot
still same issue.
I have no “above 4G decoding”/“something BAR” in my UEFI settings.
nvidia bug report attached
nvidia-bug-report.log.gz (830.3 KB)
And here is my grub file, just to make sure I am doing this right:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
pci=realloc
