Hello
While executing my application using 2 processes (mpiexec -np 2 ****.exe), I am getting the following error:
[0] fatal error
Fatal error in MPI_Reduce: Message truncated, error stack:
MPI_Reduce(804)…: MPI_Reduce(sbuf=0x0000000141121C00,
rbuf=0x000000000012F978, count=1, MPI_DOUBLE_PRECISION, MPI_MAX, root=0, MPI_COMM_WORLD) failed
MPIR_Reduce(461)…:
MPIC_Recv(72)…:
MPIDI_CH3U_Request_unpack_uebuf(599): Message truncated; 64 bytes received but buffer size is 8
It works fine with just 1 process. I am using PGI compilers to compile the code (in cygwin environment on Windows platform) and adding the MSMPI library through the -Mmpi=msmpi flag.
I suppose the msmpi.dll being used is version 2.0.1551.0 and the OS is Windows Server 2008, HPC Edition Service Pack 2
Kindly let me know if you have any suggestions to resolve this.
Thanks & Regards,
Kunal
