Hello
I want to get Jpeg files of different resolutions from one source.
I can create a JPEG 1920x1080 file with the following command.
gst-launch-1.0 -v v4l2src device=/dev/video0 \
! "video/x-raw, format=(string)UYVY, width=(int)3840, height=(int)2160, framerate=30/1" \
! nvvidconv \
! tee name=a a. \
! queue \
! "video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1" \
! nvjpegenc \
! multifilesink location=/tmp/a_%d.jpg max-files=5 -e a. \
! queue \
Is it possible to create two types of JPEG here: 1920x1080 JPEG, 640x480 JPEG?
I tried using TEE with the following command, but without success.
! nvvidconv \
! tee name=a a. \
! queue \
! nvjpegenc \
! queue \
! tee name=b b. \
! queue \
! "video/x-raw(memory:NVMM), width=640, height=480, framerate=30/1" \
! nvjpegenc \
! multifilesink location=/tmp/b_%d.jpg max-files=5 -e b. \
! queue
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.341: gst_mini_object_copy: assertion 'mini_object != NULL' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.341: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.341: gst_structure_copy: assertion 'structure != NULL' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.341: gst_caps_append_structure_full: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.342: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.342: gst_structure_copy: assertion 'structure != NULL' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.342: gst_caps_append_structure_full: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.342: gst_mini_object_unref: assertion 'mini_object != NULL' failed
(gst-launch-1.0:2013): GStreamer-CRITICAL **: 04:25:37.342: gst_mini_object_ref: assertion 'mini_object != NULL' failed
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, format=(string)UYVY, framerate=(fraction)120/1, width=(int)3840, height=(int)2160, colorimetry=(string)2:4:5:1, interlace-mode=(string)progressive
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Is it not possible to output various resolutions using TEE?
