Multi-version of Nvidia Jetpack returned
Hi;
I used “sudo apt-cache show nvidia-jetpack” to check Jetpack version of my Xavier NX. Below is the return:
Package: nvidia-jetpack
Version: 4.6.4-b39
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.4-b39), nvidia-tensorrt (= 4.6.4-b39), nvidia-nsight-sys (= 4.6.4-b39), nvidia-cudnn8 (= 4.6.4-b39), nvidia-opencv (= 4.6.4-b39), nvidia-container (= 4.6.4-b39), nvidia-visionworks (= 4.6.4-b39), nvidia-vpi (= 4.6.4-b39)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.4-b39_arm64.deb
SHA256: 22f450b9101de4df5ca2a028a1246954693f6161505e557256c51bae83c00f47
SHA1: 330b70bbd31c767b13e65f9252fcef0bfef94723
MD5sum: f43560a65e283a23c9c8727e884bd433
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6.3-b17
Architecture: arm64
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.3-b17), nvidia-tensorrt (= 4.6.3-b17), nvidia-nsight-sys (= 4.6.3-b17), nvidia-cudnn8 (= 4.6.3-b17), nvidia-opencv (= 4.6.3-b17), nvidia-container (= 4.6.3-b17), nvidia-vpi (= 4.6.3-b17)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.3-b17_arm64.deb
SHA256: bc486787ebc35228cd51b647f581e52f53e6238c0444a7654d3dcd43c6c8f6aa
SHA1: 5db526f319cae2dca64d7722cdb72bc9eaccb6c1
MD5sum: 5e44667d6e5b9d6d7ea8f0830fb83d66
Version: 4.6.2-b5
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.2-b5), nvidia-opencv (= 4.6.2-b5), nvidia-cudnn8 (= 4.6.2-b5), nvidia-tensorrt (= 4.6.2-b5), nvidia-visionworks (= 4.6.2-b5), nvidia-container (= 4.6.2-b5), nvidia-vpi (= 4.6.2-b5), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.2-b5_arm64.deb
SHA256: 3b173ce179df79348fc68254a1fa4b7c9fc1d65ff2a065de7bf70459223ac39f
SHA1: eb5f9357dffa31c6945b39d6d28f7ef31b10fda2
MD5sum: 93001822fdf68db3a47cc832a17cbce8
Version: 4.6.1-b110
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.1-b110_arm64.deb
SHA256: 312e75d89d0837472668714c43590fd204a33b9c7727c542e1b5df367ec239c4
SHA1: 769cbf1c7acb9e39a4539879884a570bde12292c
MD5sum: a074f5225dfe8d7ea24560b15eef08d9
There are 4 versions returned: 4.6.4-b39, 4.6.3-b17, 4.6.2-b5 and 4.6.1-b110. These make me quite confused. Why? I don’t know what the version actually is.
Any one can help on this? Thanks
cydu
I’m not sure what you actually want to do.
Please just run sudo install nvidia-jetpack, and it will install the right version that matches your L4T version.
Also, to see what packages are present, use “dpkg -l”. You could search more specifically like this:
dpkg -l | egrep -i 'nvidia-jetpack'
The cache itself includes some old packages. I’m not positive, but this is not exactly the same as what is currently installed.
You may also clean up old unused packages with:
sudo apt autoremove
