Multidimensional texture object array
Dear forum members,
I am currently creating a fast CUDA RabbitCT implementation, which performs backprojection on multiple input images to create a 3D output model.
I am trying to create a pipelined kernel is launched on multiple streams. For this reason, I need to define textures for each stream and for each pipeline stage. However, I seem to be unable to get a working version of this code using multidimensional arrays. I have however achieved good results using a hardcoded implementation with the code below. Notice the hardcoded object parameters ( imgTexObj[streamnr][1] ).
#define STREAMS_MAX 	4
#define PIPELINE_DEPTH 	2
cudaStream_t streams[STREAMS_MAX];
cudaArray_t imgArray[STREAMS_MAX][PIPELINE_DEPTH];
cudaTextureObject_t imgTexObj[STREAMS_MAX][PIPELINE_DEPTH];
// Called before algorithm is launched
void initialize()
   // Specify texture descriptor
   struct cudaTextureDesc texDesc;
   memset(&texDesc, 0, sizeof(texDesc));
   texDesc.addressMode[0]   = cudaAddressModeBorder;
   texDesc.addressMode[1]   = cudaAddressModeBorder;
   texDesc.filterMode       = cudaFilterModeLinear;
   texDesc.readMode         = cudaReadModeElementType;
   texDesc.normalizedCoords = false;
   for( int s = 0; s < STREAMS_MAX; s++ ){
      gpuErrchk(cudaStreamCreateWithFlags (&streams[s], cudaStreamNonBlocking));
      for( int p = 0; p < PIPELINE_DEPTH; p++){
         gpuErrchk(cudaMallocArray(&imgArray[s][p], &channelDesc, pixelsX, pixelsY, cudaArrayTextureGather));
    	 // Specify texture resource descriptor
    	 struct cudaResourceDesc resDesc;
    	 memset(&resDesc, 0, sizeof(resDesc));
    	 resDesc.resType = cudaResourceTypeArray;
    	 resDesc.res.array.array = imgArray[s][p];
    	 gpuErrchk(cudaCreateTextureObject(&imgTexObj[s][p], &resDesc, &texDesc, NULL));
__global__ void backproject(const RabbitCtKernelData_t * __restrict__ r, float* __restrict__ volume,
	const float* __restrict__ matrix, const cudaTextureObject_t __restrict__ TexObj,
const cudaTextureObject_t __restrict__ TexObj2)
   CalculateMatrixStuff();
   for each volume position{
      volume += matrixstuff * tex2D<float>(TexObj, i+0.5f, j+0.5f);
      volume += matrixstuff * tex2D<float>(TexObj2, i+0.5f, j+0.5f);
// Called for each input image
bool ExecAlgorithm(RabbitCtGlobalData* r)
   const uint streamnr = streamcnt % STREAMS_MAX;
   const uint imgnr = r->adv_projNumber % PIPELINE_DEPTH;
   // Copy input image to device memory
   const int inSize = r->S_x * r->S_y * sizeof(float);
   gpuErrchk(cudaMemcpyToArrayAsync(imgArray[streamnr][imgnr], 0, 0, r->Input, inSize,
      cudaMemcpyHostToDevice, streams[streamnr]));
   // Call kernel only when all input images have been copied
   if ( imgnr == PIPELINE_DEPTH-1) {
      dim3 threadsPerBlock( 16, 16 );
      dim3 numBlocks( r->L/threadsPerBlock.x, r->L/threadsPerBlock.y );
      backproject<<<numBlocks, threadsPerBlock, 0, streams[streamnr]>>>(r, outputptr, matrixdata,
         imgTexObj[streamnr][0], imgTexObj[streamnr][1]);
      gpuErrchk( cudaPeekAtLastError() );
Ideally, I want the textures to be passed using a pointer to the texture objects, allowing the kernel to select its data based upon the PIPELINE_DEPTH parameter. And relieving me from creating multiple hardcoded implementations for benchmarking comparisons. So, the ideal code looks something like this:
__global__void backproject(const stuff, const cudaTextureObject_t __restrict__ TexObj)
      for( stage = 0; stage < PIPELINE_DEPTH; stage++ ){
         volume += matrixstuff * tex2D[stage]<float>(TexObj, i+0.5f, j+0.5f);
bool ExecAlgorithm
         imgTexObj[streamnr]);
Where only the texture objects for a single stream are passed as each kernel operates in only a single stream. Passing the entire texture array is also not a problem.
I have tried several options, but I always end up with either a segfault at my mallocs for the array or an illegal memory access at line 57 from the current implementation example.
Could anybody help me get a good implementation of this global multidimensional texture object array?
Kind regards,
Remy
I’ve not studied your code to determine where the problem lies. You’ve not provided a complete code nor provided a specific error to chase. Currently I don’t have the time to write a multidimensional texture object array example from scratch.
Here’s a worked example showing a single dimension texture object array:
[url]c++ - Cuda Create 3d texture and cudaArray(3d) from device memory - Stack Overflow
Presumably, if hard pressed, you could simply map your 2D array into a 1D array.
Hey txbob,
Thanks for your response. I understand that understanding somebody else’s code to understand an issue can take too much time. The only issue is that with RabbitCT you compile to a .DLL, which requires you to compile and link the host code as well.
Luckily, I managed to solve the issue today by introducing a 3D array containing pointers to the texture objects. I used the Malloc3D example from the programming guide for anyone with similar problems:
[url]Programming Guide :: CUDA Toolkit Documentation
Kind regards,
Remy
