Hi all,
I am trying to publish joint information (transform and rotate) for a spherical joint, is there a way to do it via action graph in Isaac Sim? specifically, similar to the MultiDOFJointState Message in ROS2.
I have success with publishing the joint state for prismatic and revolute joints (action graph attached), but not with other joint type.
I am using ros2 humble and Isaac Sim 2022.1.1.
Thank you,
J
