Hi Everybody:
I am trying to modify my code, so instead of just use one GPU for the calculations use two of them. My program has the option to run with pageable or pinned memory.
For one GPU is running ok, with no problems, but for the new code I am always having problems if I try to run for 2 GPU.
For pinned memory I always get the following problem.
Waiting for GPUs results …
set device
set device
device 0 test 0
Allocate memory in device 0
device 1 test 0
Allocate memory in device 1
PET_GPU_sm11.cu(1661) : cudaSafeCall() Runtime API error : no CUDA-capable device is available.
and for pageable memory
set device
device 0 test 1
set device
device 1 test 1
Copy memory to device 0
Copy memory to device 1
Device = 0 Gx = 65535 Gy = 1
Copy results to Host 0
Device = 1 Gx = 65535 Gy = 1
Copy results to Host 1
PET_GPU_sm11.cu(1748) : cudaSafeCall() Runtime API error : unspecified launch failure.
This is the part of my code where im doing all the GPU settings and launching the kernel
[codebox]
static CUT_THREADPROC solverThread(TGPUplan *plan)
short int* DEV_vec_struct;
float* DEV_weight;
int* DEV_index;
int* DEV_vec_entry;
short int* DEV_lookup;
float* DEV_proj_space;
float* DEV_image_space;
int* DEV_vec_check;
printf(“set device \n”);
//Set device
cutilSafeCall( cudaSetDevice(plan->device) );
//cudaStream_t stream1;
// cudaStreamCreate(&stream1);
printf(“device %d test %d\n”,plan->device, plan->test);
int nsize_s=plan->nlength_shortint*sizeof(short int);
int nsize_w=plan->nmatrix_elements*sizeof(float);
int nsize_i=plan->nmatrix_elements*sizeof(int);
int nsize_ve=2plan->nvecssizeof(int);
int nsize_lk=plan->nsymmetriesplan->nsymmetriessizeof(short int);
int nsize_proj=plan->nsymmetriesplan->nvecssizeof(float);
int nsize_img=plan->nfieldsplan->nlengthsizeof(float);
int nsize_ck=10plan->nvecssizeof(int);
//Initialization of results
//memset(plan->proj_space,0,nsize_proj);
//memset(plan->vec_check,0,nsize_ck);
// Allocate memory
printf(“Allocate memory in device %d \n”,plan->device);
cutilSafeCall(cudaMalloc((void**) &DEV_vec_struct, nsize_s));
cutilSafeCall(cudaMalloc((void**) &DEV_weight, nsize_w));
cutilSafeCall(cudaMalloc((void**) &DEV_index, nsize_i));
cutilSafeCall(cudaMalloc((void**) &DEV_vec_entry, nsize_ve));
cutilSafeCall(cudaMalloc((void**) &DEV_lookup, nsize_lk));
cutilSafeCall(cudaMalloc((void**) &DEV_proj_space,nsize_proj));
cutilSafeCall(cudaMalloc((void**) &DEV_image_space, nsize_img));
cutilSafeCall(cudaMalloc((void**) &DEV_vec_check, nsize_ck));
//Copy input data from CPU
printf(“Copy memory to device %d \n”,plan->device);
if (plan->test){
cutilSafeCall(cudaMemcpy(DEV_vec_struct, plan->vec_struct, nsize_s,
cudaMemcpyHostToDevice) );
cutilSafeCall(cudaMemcpy(DEV_weight, plan->weight, nsize_w,
cutilSafeCall(cudaMemcpy(DEV_index, plan->index, nsize_i,
cutilSafeCall(cudaMemcpy(DEV_vec_entry,plan->vec_entry,nsize_ve,
cutilSafeCall(cudaMemcpy(DEV_lookup, plan->symm_lookup, nsize_lk,
cutilSafeCall(cudaMemcpy(DEV_proj_space,plan->proj_space,nsize_proj,
cutilSafeCall(cudaMemcpy(DEV_image_space, plan->flatimage, nsize_img,
cutilSafeCall(cudaMemcpy(DEV_vec_check, plan->vec_check, nsize_ck,
else{
cutilSafeCall(cudaMemcpyAsync(DEV_vec_struct, plan->vec_struct, nsize_s,
cudaMemcpyHostToDevice,0) );
cutilSafeCall(cudaMemcpyAsync(DEV_weight, plan->weight, nsize_w,
cutilSafeCall(cudaMemcpyAsync(DEV_index, plan->index, nsize_i,
cutilSafeCall(cudaMemcpyAsync(DEV_vec_entry,plan->vec_entry,nsize_ve,
cutilSafeCall(cudaMemcpyAsync(DEV_lookup, plan->symm_lookup, nsize_lk,
cutilSafeCall(cudaMemcpyAsync(DEV_proj_space,plan->proj_space,nsize_proj,
cutilSafeCall(cudaMemcpyAsync(DEV_image_space, plan->flatimage, nsize_img,
cutilSafeCall(cudaMemcpyAsync(DEV_vec_check, plan->vec_check, nsize_ck,
//Perform GPU computations
//—setup execution parameters
int tX=320;
int tY=1;
dim3 threads(tX, tY);
int gY=(plan->nvecs + 65535)/65535;
int gX=65535;
printf(“Device = %d Gx = %d Gy = %d \n”,plan->device,gX,gY);
dim3 grid(gX, gY);
int nv = plan->nvecs;
//—execute the kernel
matrixMul<<< grid, threads >>>(DEV_vec_struct, DEV_weight, DEV_index,
DEV_lookup, DEV_proj_space, DEV_image_space, DEV_vec_entry,
DEV_vec_check,nv);
//—check if kernel execution generated and error
cutilCheckMsg(“Kernel execution failed”);
// if (plan->test == false)
cutilSafeCall(cudaThreadSynchronize()); /// Add to check correct time
printf(“Copy results to Host %d\n”,plan->device);
if (plan->test)
cutilSafeCall(cudaMemcpy (plan->proj_space, DEV_proj_space, nsize_proj,
cudaMemcpyDeviceToHost) );
else
cutilSafeCall(cudaMemcpyAsync(plan->proj_space, DEV_proj_space, nsize_proj,
cudaMemcpyDeviceToHost,0) );
//if (plan->test == false)
//Blocks until the device has performed all task requested
//cutilSafeCall(cudaThreadSynchronize());
// Shutdown this GPU
printf(“Free memory from device %d\n”,plan->device);
cutilSafeCall(cudaFree(DEV_vec_struct));
cutilSafeCall(cudaFree(DEV_weight));
cutilSafeCall(cudaFree(DEV_index));
cutilSafeCall(cudaFree(DEV_vec_entry));
cutilSafeCall(cudaFree(DEV_lookup));
cutilSafeCall(cudaFree(DEV_proj_space));
cutilSafeCall(cudaFree(DEV_image_space));
cutilSafeCall(cudaFree(DEV_vec_check));
cudaThreadExit();
CUT_THREADEND;
[/codebox]
Line 1661 is cudaSafeCall() Runtime API error : no CUDA-capable device is available.
and Line 1748 is cutilSafeCall(cudaMemcpy (plan->proj_space, DEV_proj_space, nsize_proj,
Basically this program is based on the MonteCarloMultiGPU.cpp. this program runs succesfully with no problems.
Any ideas, why the program crashes?
Luis Garcia
