I have an application in CUDA that process images, and it works perfect for some images.
If the image is bigger, I get the “launch timed out” problem.
I have a 9800GX2 card, and the problem should be fixed if I use the GPU that is not configured as main display.
I’d like to know how can I tell the compiler or application to use the second GPU instead of the first one (display) to run the application.
I run the simpleMultiGPU app from the SDK, and it works well without errors, but I don’t understand how it works. :wacko:
Help me please!
Thank you very much.
LSChien
2
you can use runtime library to set which device you want , first use deviceQuery in SDK to check your configuration,
your card 9800GX2 has two GPUs, labeled as GPU0 and GPU1, suppose you want to use GPU1, then
[codebox] cudaDeviceProp deviceProp;
int device = 1 ; // choose device 1
cudaGetDeviceProperties(&deviceProp, device);
cudaSetDevice( device );
printf("use device %d, name = %s\n", device, deviceProp.name );[/codebox]
in simpleMultiGPU example, it set each host thread to different GPU via
[codebox] for(i = 0; i < GPU_N; i++){
plan[i].device = i; % i-th GPU
plan[i].h_Data = h_Data + gpuBase;
plan[i].h_Sum = h_SumGPU + i;
gpuBase += plan[i].dataN;
}[/codebox]
and bind current host thread to i-th GPU by “cudaSetDevice” in function “solverThread”
[codebox]static CUT_THREADPROC solverThread(TGPUplan *plan){
const int BLOCK_N = 32;
const int THREAD_N = 256;
const int ACCUM_N = BLOCK_N * THREAD_N;
float *d_Data,*d_Sum;
float *h_Sum;
float sum;
int i;
//Set device
cutilSafeCall( cudaSetDevice(plan->device) );[/codebox]
