Multimedia Application Framework APIs in samples directory
I’m building an application with the Multimedia API and I see that all of the classes under ‘Application Framework API’ are in the directory tegra_multimedia_api/samples/common/classes/
Why are they under the ‘samples’ directory? Are they not production quality?
Hi, I think that means sample code.
You know, android also has sample code, but it doesn’t means android is not production quality.
