When using the NVMEDIA_IPP_COMPONENT_FILE_READER, calling NvMediaIPPPipelineSingleCapture causes the pipeline to call the NvMediaIPPFileReaderComponentConfig imageGroupReadCallback multiple times. It appears to have the same effect as if I just started the pipeline in a free run mode. I would expect the callback to get called only once per time I call NvMediaIPPPipelineSingleCapture.
Below is sample code for how I setup the pipeline. Is there another setting I need to set to make sure that triggered mode only happens once when NvMediaIPPPipelineSingleCapture is called?
symptoms:
First image is in the queue and is processed correctly.
Reader call back is called before another image is ready to be processed if queue is empty then I return NVMEDIA_STATUS_OK
It appears an empty image is processed through the ISP and the output image is blank.
Because save and load are expensive, the number of blank images is the size of the configured image pool.
If I return NVMEDIA_STATUS_ERROR when there are no images to process then it seems to stop the entire image pipeline.
How can I setup the pipeline so that I will guarantee that I will only get 1 callback per NvMediaIPPPipelineSingleCapture call?
ext_img_device_ = ExtImgDevInit(params);
manager_ = NvMediaIPPManagerCreate(NVMEDIA_IPP_VERSION_INFO, ext_img_device_);
pipeline_ = NvMediaIPPPipelineCreate(manager_);
// setup triggered mode.
bool triggered = NVMEDIA_TRUE;
constexpr size_t PROP_SIZE = 2;
NvMediaIPPPipelineProperty properties[PROP_SIZE];
properties[0].type = NVMEDIA_IPP_PIPELINE_PROPERTY_TRIGGER_BASED_CAPTURE;
properties[0].value = &triggered;
uint32_t frame_delay = 0;
// Set this to indicate take settings immediately, but didn't have any noticeable effect.
properties[1].type = NVMEDIA_IPP_PIPELINE_PROPERTY_SETTINGS_DELAY;
properties[1].value = &frame_delay;
CHECK_NVMEDIA_STATUS_OK(
NvMediaIPPPipelineSetProperties(pipeline_, PROP_SIZE, properties));
components = file_reader, isp, acp, isc, output;
// Create Components
for each component { NvMediaIPPComponentCreateNew(...); }
// Attach Components
for each component { NvMediaIPPComponentAttach(...); }
// Process images
for (image in images) {
image = load_image();
in_queue_.push(image);
// For some reason this triggers continuous reader callbacks
NvMediaIPPPipelineSingleCapture(...);
out_queue_.wait_for_image();
save_image(out_queue_.pop());
// Images are pushed to the reader callback image queue and processed in the ISP.
// When all images are done being processed cleanup
// Stop Pipeline
NvMediaIPPPipelineStop(...);
// Destroy Components
for each component { NvMediaIPPComponentDestroy(...); }
NvMediaIPPPipelineDestroy(pipeline_);
NvMediaIPPManagerDestroy(manager_);
ExtImgDevDeinit(ext_img_device_);
