Multiple camera preview
Is there any possibility to preview multiple gmsl2 camera on AGX carrier board and redirect to specified display in multi display system?
Thanks and Regards
Darshan
Try export DISPLAY=:[0|1] before launch camera APP from command line.
Hi ,
Thanks for replay ,
i tried with export DISPLAY=1 and gstreamer command , it is not working
we are not using any camera APP for preview , we are using gst-launch command to preview .
Please let us know how to use a gstreamer command for multi display system.
clear picture of my query is , when i run gstreamer command i able to see two camera preview in primary display , but i need to redirect two camera preview to other display.
The command should be
export DISPLAY=:1
Ya ,I tried the same it not working
What kind of gstreamer pipeline you are using now? Which sink node is that?
Hi ,
I am using xvimagesink with v4l2src pipeline
I am not sure if xvimagesink has any display-id node, could you check that first? This is not nvidia software components.
nvoverlaysink shall have display-id node to choose.
Ya , I tried with nvoverlaysink with that we can redirect only one camera preview .
I want redirect multiple camera preview to specified display.
How about testing the simplest way first? Launch two pipeline and see if you can render to different monitors.
Yes , we can render to two different monitor.
But i want to render to single monitor.
Why not you share your pipeline?
Ya , we are using this command to redirect one camera preview
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420, width=(int)1920,
height=(int)1080" ! nvoverlaysink overlay-w=1920 overlay-h=1080 display_id=1
If we use following command then we can see two camera preview in two different monitor
height=(int)1080" ! nvoverlaysink overlay-w=1920 overlay-h=1080 display_id=1 & gst-launch-1.0 v4l2src device=/dev/video1 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420, width=(int)1920, height=(int)1080" ! nvoverlaysink overlay-w=1920 overlay-h=1080 display_id=2
But i want see two camera preview in same specified monitor
You can use the gst-inspect to check what parameters you can use for nvoverlaysink. There is something called overlay id.
Hi ,
we checked with gst-inspect ,nvoverlaysink as no property like overlay-id
You can check and try something that you think it might work. I also don’t memorize every property for each gst components.
For your case, it is not overlay-id but overlay.
overlay : Overlay index
flags: readable, writable
Unsigned Integer. Range: 0 - 5 Default: 1
overlay-depth : Overlay depth
Unsigned Integer. Range: 0 - 2 Default: 0
overlay-x : Overlay X coordinate
Unsigned Integer. Range: 0 - 4294967295 Default: 0
overlay-y : Overlay Y coordinate
overlay-w : Overlay Width
overlay-h : Overlay Height
overlay-profile : Overlay Profile
display-id : Display on which overlay should be rendered
we tried with ovrelay property , then also we are not able to preview two camera
Share the command and if you have error log on the screen.
Things cannot proceed if you only say something like cannot work.
I tried with this command
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420, width=(int)800, height=(int)500" ! nvoverlaysink overlay-h=600 overlay-w=600 overlay-x=200 overlay-y=200 display_id=1 overlay=1 & gst-launch-1.0 v4l2src device=/dev/video1 ! "video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420, width=(int)800, height=(int)500" ! nvoverlaysink overlay-h=480 overlay-w=480 overlay-x=800 overlay-y=800 display_id=1 overlay=2
I am getting error like as bellow
[1] 12353
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.622655031
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Overlay is assigned to each monitor. There are total 6 overlays.
You can just try different numbers for overlay to see which one would work.
