Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
In our setup we’re using 6 cameras: 4 connected to deserializer A, 2 connected to deserializer C, all recorded at 15FPS (frame-mod=2). to verify the alignment between the cameras I ran the following test:
- record using driveworks recorder (with the attached rig)
- extract all frames
- align the frames to maintain only the overlapping frames from when all cameras are up
- take footage of a timer running over the screen with all cameras
- show all frames in a collage to see if they’re truly aligned, meaning all frames will show same timestamp + the timer will show the same time in the image.
I shared here (attached) a few examples from this test and the results are as follows:
- these cameras are all synced to the millisecond: rear_left, rear_center, front_right, front_left. you can see they have the same timestamp printed (i took it from the timestamps file) and they display the same timer time.
- these cameras are synced but 33ms delayed relative to cameras in (1): rear_right, front_center.
I thought that this could be related to the fact that they’re on different deserializers but in fact as you can see from the rig:
- front_center, rear_center, front_right, rear_right are connected to deserializer A.
- rear_right, rear_left are connected to deserializer C.
so it seems unrelated.
My questions are:
- is this epxected behavior? we’re expecting all cameras from all deserializers to be sycned (according to the GPIO signal).
- how can this be solved? we would like all cameras to be synced to the same timestamp.
online_rig.txt (8.9 KB)
