We are configuring multiple aurix can channels using easy can config.We can’t receive more than one can channel on Tegra A.
If we configure very less messages (Like 2 to 5 messages) on different channels, and try to receive those on different channels, then it works fine. But we can’t configure all the messages from dbc in all the channels and receive the expected result.
I am not sure if this is the known issue for Easy CAN config?
EasyCAN is for easier initial development only and the performance is limited.
If all 6 CAN channels are configured, then there will be message drops. Thanks.
Did you figure out how to use multiple aurix can channels working at the same time? It will be highly appreciated if you can share what you found if you figured out!
One more question, when I turn on more than one aurix can channels at a time, only the last one works. If I run individual each channel, they all works. I wonder if there is sth. wrong with my setup for the aurix can. Below is my setup,
one channel I set in this way:
params.protocol = “can.aurix”;
params.parameters = “ip=10.42.0.146,bport=60395,bus=a,config-file=/usr/local/driveworks/data/samples/sensors/can/EasyCanConfigFile.conf”;
the other channel I set in this way:
params.parameters = “ip=10.42.0.146,bport=60395,bus=b,config-file=/usr/local/driveworks/data/samples/sensors/can/EasyCanConfigFile.conf”;
I went through some discussion. somebody said we need to change the bport value. But I could not find another working value other than 60395. Could you help me out?
