Is it possible to run cublas functions for different matrices at the same time on the same GPU?
For example,
1st block will make an operation on matrix A
and
2nd block will make an operation on matrix B
thanks in advance,
For example,
and
thanks in advance,
You want to use cublas function in a kernel func?
I don’t think you can because cublas already uses the cuda api. You may try by using a cublas function in a kernel ie :
#include "cublas.h"
__global__ void kernelfunc() {
cublasInit();
I tried it but it caused an error about using a host function in a kernel. I think it does not allow cublas functions in a kernel. :(
You have to implement this in an iterative way. But you know that cublas functions are already optimised for speed so you don’t need to change anything.
CUBLAS Library is Host API Library (e.g that must be called from the Host) that internally launch GPU kernels.
However, pointers passed to cublas routines must be device pointers.
