Multiple CUDA/RTX/Vulkan application crashing with Xid (13,109) errors
Is anyone reporting here using overclocking/undervolting? I know that when I push it too far and the GPU glitches, I get Xid 109. If nothing else, it seems like this error code can be caused by all sorts of things, and so it’s possible for them to fix one or more causes, and there still be plenty of them left. (eg: Whatever caused it in Metro Exodus EE seems to be fixed, but not others)
It’s an ASUS TUF Gaming F15 laptop. Default settings, didn’t mess around with overclocking/undervolting at all.
That is probably because you have vkd3d 2.8 selected in Lutris while with Steam and Proton you are using 2.9.
2.9 has a workaround for this issue.
  • Workaround NVIDIA bug with concurrent queue submissions using timeline semaphores.
    Fixed a bunch of inexplicable Xid 109 CTX_SWITCH_TIMEOUT errors in many different games.
Weird that Cities Skylines without proton works just fine while ETS2 endlessly crashes.
I’m using the latest version of nvidia-open
I have updated the engineering team regarding game crash, shall keep updated on the findings.
Tried running Metro Exodus Enhanced and the issues still persists.
Have not tried it with nvidia beta driver 535.43.02
NVIDIA driver: 530.41.03
Proton: Proton-GE-8-3
Kernel: 6.1 Manjaro
Proton-GE has the by @VulkanGuy mentioned vk3d workaround included.
[35083.663983] NVRM: Xid (PCI:0000:0a:00): 13, pid='<unknown>', name=<unknown>, Graphics SM Warp Exception on (GPC 4, TPC 1, SM 0): Illegal Instruction Parameter
[35083.663995] NVRM: Xid (PCI:0000:0a:00): 13, pid='<unknown>', name=<unknown>, Graphics Exception: ESR 0x524f30=0xb 0x524f34=0x0 0x524f28=0xf812b60 0x524f2c=0x1104
[35088.001627] NVRM: Xid (PCI:0000:0a:00): 109, pid=74797, name=MetroExodus.exe, Ch 000000a6, errorString CTX SWITCH TIMEOUT, Info 0x7c056
Tried as well with Sea of Thieves, both with proton and without. The game crashes with the same Xid error
Same issue here with Eve Online via flatpak Steam + Proton experimental. I’ve tested 535.xx, 530.xx, 525.xx and 520.xx - 520.56.06 is the only version that’s stable for more than 10 minutes or so without hitting the CTX timeout crash.
Just hit this within 10 minutes testing 535.43.02 earlier:
Jun 03 23:28:05 archx16 kernel: NVRM: Xid (PCI:0000:01:00): 109, pid=16259, name=exefile.exe, Ch 0000002e, errorString CTX SWITCH TIMEOUT, Info 0xac020
edit: Same issue with Proton-GE 8.3, the vkd3d-proton mitigation doesn’t fix this.
I’m experiencing the same crash on Forza Horizon 5. It seems to be incredibly random; sometimes I can play for hours and other times it will crash many times in quick succession.
Driver version: 530.41.03
Proton versions: Proton 8.0-2, Proton Experimental, Proton-GE 8.3
Kernel: 6.3.5
NVRM: Xid (PCI:0000:26:00): 109, pid=185806, name=ForzaHorizon5.e, Ch 00000059, errorString CTX SWITCH TIMEOUT, Info 0x2c030
I am also getting the same error with Forza Horizon 5. Ultra settings+ray tracing enabled+dlss quality.
NVRM	GPU at PCI:0000:01:00: GPU-f747ea3e-3513-2681-8d42-53e8fc2533d1
NVRM	Xid (PCI:0000:01:00): 109, pid=4078, name=ForzaHorizon5.e, Ch 00000016, errorString CTX SWITCH TIMEOUT, Info 0x1c00f
Driver: 530.41.03
Proton experimental
Kernel: 6.1.31
HW: Asus TUF A15 FA507XI-LP024 with RTX4070
Forza Horizon 5 & Horizon Zero Dawn give me XID 31.
Here dmesg from Zero Dawn, but it is the same error for FH5:
NVRM: Xid (PCI:0000:07:00): 31, pid=9017, name=HorizonZeroDawn, Ch 000000a6, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
NVRM: Xid (PCI:0000:07:00): 31, pid=9017, name=HorizonZeroDawn, Ch 000000a6, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_8 faulted @ 0x60_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Linux Kernel Version: 6.3.5
Driver Version: 535.43.02
Proton Version: Proton Experimental (but also tried with GE-8.4)
GPU: 3080 Ti
Also tried with multiple resolutions and graphics settings.
nvidia-smi output when the game freezes:
Sun Jun 11 18:22:04 2023
| NVIDIA-SMI 535.43.02              Driver Version: 535.43.02    CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 3080 Ti     Off | 00000000:07:00.0  On |                  N/A |
| 58%   47C    P5              44W / 350W |   8267MiB / 12288MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A      2341      G   /usr/bin/X                                  633MiB |
|    0   N/A  N/A      2465      G   /usr/bin/ksmserver                            4MiB |
|    0   N/A  N/A      2467      G   /usr/bin/kded5                                4MiB |
|    0   N/A  N/A      2469      G   /usr/bin/kwin_x11                             5MiB |
|    0   N/A  N/A      2520      G   /usr/bin/plasmashell                         72MiB |
|    0   N/A  N/A      2583      G   ...c/polkit-kde-authentication-agent-1        4MiB |
|    0   N/A  N/A      2585      G   ...ib64/libexec/xdg-desktop-portal-kde        4MiB |
|    0   N/A  N/A      2654      G   /usr/bin/nextcloud                           21MiB |
|    0   N/A  N/A      2662      G   /usr/lib64/libexec/kdeconnectd                4MiB |
|    0   N/A  N/A      2671      G   /usr/bin/kaccess                              4MiB |
|    0   N/A  N/A      2676      G   /usr/lib64/libexec/DiscoverNotifier           4MiB |
|    0   N/A  N/A      2683      G   /usr/bin/kmix                                 4MiB |
|    0   N/A  N/A      3087      G   ...local/share/Steam/ubuntu12_32/steam        8MiB |
|    0   N/A  N/A      3137      G   ...re/Steam/ubuntu12_64/steamwebhelper       10MiB |
|    0   N/A  N/A      3220      G   ...eam/logs/cef_log.txt --shared-files      118MiB |
|    0   N/A  N/A      4337    C+G   ...rizon Zero Dawn\HorizonZeroDawn.exe     7260MiB |
|    0   N/A  N/A      5511      G   /usr/lib64/libexec/baloorunner                4MiB |
|    0   N/A  N/A      5515      G   /usr/bin/konsole                              4MiB |
I get a similar error with Half Life: Alyx (both Proton and Native). On Proton it also freezes no matter what API is selected (DX11 or Vulkan). The also freezes on Windows as well (Not sure where to look in the Event Viewer for any relevant errors though).
The error message I get on Linux is…
NVRM: Xid (PCI:0000:0b:00): 109, pid=2867, name=hlvr, Ch 000000a9, errorString CTX SWITCH TIMEOUT, Info 0x2c05d\x0a
Linux Kernel Version: 6.3.7-lqx1
Linux Driver: 535.43.02
Windows Version: 10 and 11
Windows Driver: 535.98
GPU: RTX 3080TI
EDIT: I’ve tried Linux drivers 525.116.04 and 515.105.01 and both still freeze with Half Life: Alyx.
Interestingly, while 525.116.04 produces the Xid 109 error 515.105.01 just completely freezes my Wayland session.
I updated to 535.54.03 earlier today and the frequency of these crashes is much reduced. I thought it was solved but crashed out of EVE Online after about 4h.
This probably isn’t all that helpful without more info (let me know how to gather that and I will) but here’s the kernel error:
Jun 14 19:28:46 archx16 kernel: NVRM: GPU at PCI:0000:01:00: GPU-c2ed6dd4-1b00-1898-35cf-151512712cc3
Jun 14 19:28:46 archx16 kernel: NVRM: Xid (PCI:0000:01:00): 109, pid=21516, name=exefile.exe, Ch 00000036, errorString CTX SWITCH TIMEOUT, Info 0x23c020
Arch Linux
Steam via flatpak
Proton-GE 8.4
nvidia dkms driver 535.54.03
Linux kernel 6.3.7
I’ve seen crashes in a few games, just now I had one in Ghostrunner.
Xid 109 error.
I’m on 535.54.03, latest driver.
I had a full system hang in Dying Light 2 earlier, though it was a BUNCH of Xid errors:
Jun 14 15:30:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 31, pid=47904, name=Xwayland, Ch 000000c0, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_00744000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
Jun 14 15:31:13 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 31, pid=47904, name=Xwayland, Ch 000000c0, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_005b4000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
Jun 14 15:31:36 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 31, pid=49580, name=Xwayland, Ch 000000c0, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_0071c000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
Jun 14 15:31:39 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 31, pid=49580, name=Xwayland, Ch 000000c0, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_00574000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
Jun 14 15:33:10 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 31, pid=57656, name=Xwayland, Ch 000000c0, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_PROP_0 faulted @ 0x1_00570000. Fault is of type FAULT_PTE ACCESS_TYPE_VIRT_READ
Jun 15 08:26:12 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 109, pid=2425408, name=AlienIsolation, Ch 00000104, errorString CTX SWITCH TIMEOUT, Info 0x4c08d
Jun 15 08:38:32 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 109, pid=2443841, name=AlienIsolation, Ch 00000104, errorString CTX SWITCH TIMEOUT, Info 0x43c090
Jun 15 08:39:08 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 109, pid=2443841, name=AlienIsolation, Ch 00000104, errorString CTX SWITCH TIMEOUT, Info 0x43c081
Jun 15 08:39:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 13, pid='<unknown>', name=<unknown>, Graphics SM Warp Exception on (GPC 1, TPC 1, SM 0): Illegal Instruction Encoding
Jun 15 08:39:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 13, pid='<unknown>', name=<unknown>, Graphics Exception: ESR 0x50cf30=0x290009 0x50cf34=0x0 0x50cf28=0xe812b60 0x50cf2c=0x1174
Jun 15 08:39:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 13, pid=2443841, name=AlienIsolation, Graphics Exception: ChID 0104, Class 0000c797, Offset 00000000, Data 00000000
Jun 15 08:57:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid='<unknown>', name=<unknown>, 0000(0000) 00000000 00000000
Jun 15 08:57:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:57:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:58:21 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:58:22 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:58:23 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:58:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:24 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:54 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:59:54 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:59:55 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:59:56 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 62, pid=2463639, name=DyingLightGame_, 0000(0000) 00000000 00000000
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000f8
Jun 15 08:59:57 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000fe
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 000000ff
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000100
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000101
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000102
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000103
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000104
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000105
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000106
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000107
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000108
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 00000109
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010a
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010b
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010c
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010d
Jun 15 08:59:58 matt-archlinux kernel: NVRM: Xid (PCI:0000:0f:00): 45, pid=2463639, name=DyingLightGame_, Ch 0000010e
I don’t mean to be obnoxious, but does NVIDIA have any updates for this issue? The laptop I have is basically unusable currently as a result of this. It’s a glorified paperweight.
Updated to Nvidia Driver 535.54.03 - the problem persists.
Horizon Zero Dawn:
NVRM: Xid (PCI:0000:07:00): 31, pid=7367, name=HorizonZeroDawn, Ch 00000096, intr 00000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Forza Horizon 5:
NVRM: Xid (PCI:0000:07:00): 109, pid=13779, name=ForzaHorizon5.e, Ch 000000a1, errorString CTX SWITCH TIMEOUT, Info 0x6c047
Nvidia-smi:
Sun Jun 18 21:33:10 2023
| NVIDIA-SMI 535.54.03              Driver Version: 535.54.03    CUDA Version: 12.2     |
|                                         |                      |               MIG M. |
|  0%   47C    P8              39W / 350W |   2269MiB / 12288MiB |      3%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A      2189      G   /usr/bin/X                                   36MiB |
|    0   N/A  N/A      2420      G   /usr/bin/kwin_wayland                       667MiB |
|    0   N/A  N/A      2477      G   /usr/bin/Xwayland                            61MiB |
|    0   N/A  N/A      2498      G   /usr/bin/ksmserver                            3MiB |
|    0   N/A  N/A      2500      G   /usr/bin/kded5                                3MiB |
|    0   N/A  N/A      2519      G   /usr/bin/plasmashell                        525MiB |
|    0   N/A  N/A      2534      G   ...c/polkit-kde-authentication-agent-1        3MiB |
|    0   N/A  N/A      2536      G   ...ib64/libexec/xdg-desktop-portal-kde        3MiB |
|    0   N/A  N/A      2677      G   /usr/bin/nextcloud                            3MiB |
|    0   N/A  N/A      2689      G   /usr/lib64/libexec/kdeconnectd                3MiB |
|    0   N/A  N/A      2691      G   /usr/bin/latte-dock                         169MiB |
|    0   N/A  N/A      2699      G   /usr/bin/kaccess                              3MiB |
|    0   N/A  N/A      2705      G   /usr/lib64/libexec/DiscoverNotifier           3MiB |
|    0   N/A  N/A      2712      G   /usr/bin/kmix                                 3MiB |
|    0   N/A  N/A      3521      G   ...local/share/Steam/ubuntu12_32/steam        8MiB |
|    0   N/A  N/A      3528      G   ...re/Steam/ubuntu12_64/steamwebhelper       56MiB |
|    0   N/A  N/A     14524      G   /opt/firefox/firefox-bin                    478MiB |
|    0   N/A  N/A     15169      G   /usr/lib64/libexec/baloorunner                3MiB |
|    0   N/A  N/A     15250      G   /usr/bin/konsole                              3MiB |
Kernel version: 6.3.7
Driver version: 535.54.03
Proton version: Experimental & GE-8.4
GPU: 3080 Ti
@amrits any updates?
Nvidia driver 520.56.06 compiled for kernel 6.0.19 works to avoid “CTX SWITCH TIMEOUT” errors on Arch Linux. 520.56.06 does not build (dkms) against newer kernels for me. No newer kernels and Nvidia driver combinations have worked for me- they all crash with “CTX SWITCH TIMEOUT” after 10-45 minutes of gaming.
Something broke after 520.56.06 or 6.0.x kernels.
The issue seems to be fixed!
Edit: As long as the Xid 31 is caused by CTX_SWTICH_TIMEOUT got another game with a different Error caused by Xid 31 but with FAULT_PTE ACCESS_TYPE_VIRT_READ.
Will open up a new thread as it is not related to this issue.
I successfully ran Metro Exodus PC Enhanced Edition and the Linux Native Version with the settings outline at the very beginning of this thread and it worked as I was able to proceed into the game. Which wasn’t possible earlier.
Tested it using Proton Experimental (experimental-8.0-20230606) with VKD3D 2.9 and with Proton 8.0-2 with VKD3D 2.8 both ran fine.
VKD3D 2.9
VKD3D 2.8
Vulkan (Linux Native version)
Will test a few other games I witnessed this issue but wanted to note that on my Setup:
OS: openSUSE Aeon
KERNEL: 6.3.7-1-default
CPU: AMD Ryzen 7 1800X Eight-Core
GPU: NVIDIA GeForce RTX 3080
GPU DRIVER: NVIDIA 535.54.03
RAM: 16 GB
everything seems to operates normal.
How are you getting fast the missing system requirements dialog? I can’t click on the 'Retry Anyway" and I can’t tab over to it and pick it with the keyboard either.
Something like this never poped up for me. 😕
My wild guess would be you might be missing dxvk-nvapi? Usually it should ship with Proton (assuming you run it via Steam) otherwise look for nvapi or dxvk-nvapi in your managing software like Lutris or Bottles.
