Multiple kernels overlaping output
Hi all again. I guess i have described what I doing several times by now(sorry for that). I am now on the right track but I have a problem. I have two .cu files, one that gives me the intersections of a ray with the xx axis and the other with the yy axis. Given that I cannot dynamically allocate memory with CUDA, I do not use all the space available in the output array, so in the end I have some “nan” values. However, if I run interx.cu and afterwards run intery.cu, where there were "nan"s, I will have values from the first file ran(interx.cu). I am using both Free and cudaFree so I am a bit confused about why these values are not deleted from execution to execution.
I had some more serious problems, that I overcame, but I cannot see where is the problem here. Thank you in advance ;)
#include <stdlib.h>
#include <stdio.h>
#define blocksize 8
#define iiterations 0
#define jiterations 0
/*The plan will be: split the initial dimensions by 8 and work those 8 parts individually, i.e, I reconstruct the first 88x112 block, free the memory and then go on to the next step, however, I think I need to apply the OSEM after each block*/
__global__ void sysmat(float*intersectionsx,float xfocus,float yfocus, float zfocus, int xbin,int xbinsize,int ybin,int ybinsize, int zbin,int zbinsize,int detectorXDim,int detectorYDim, int projecoes,int detectorZDim, int iiterationsu,int jiterationsu,int angle)
	//COMPUTE XFOCUS,YFOCUS AND ZFOCUS WITH ANGLE AND DISTANCES TO DETECTOR
	int tx=threadIdx.x, ty=threadIdx.y,bx=blockIdx.x, by=blockIdx.y;
	float x,y,z,t;
	int idy=(ty+by*blocksize)+jiterationsu;
	int idx=(tx+bx*blocksize)+iiterationsu;
	//Calculo de u, v, w
	float slopeVectorx=xfocus-(idx+0.5)*xbinsize;
	float slopeVectory=yfocus-(idy+0.5)*ybinsize;
	float slopeVectorz=zfocus;
	__syncthreads();
	//xx axis intersections
	int xint=idx+1;
	for(xint=xint; xint<=detectorXDim/2;xint++){
		x=(float)((float)xint*xbinsize);
		t=(float)((x-(float)(idx+0.5))/slopeVectorx);
		y=(float)((float)(idy+0.5)+t*slopeVectory);
		z=-17+t*slopeVectorz;
		intersectionsx[(((idx-iiterationsu)+88*(idy-jiterationsu))*(detectorXDim/2)+(xint-1))*3]=x;
		intersectionsx[(((idx-iiterationsu)+88*(idy-jiterationsu))*(detectorXDim/2)+(xint-1))*3+1]=y;
		intersectionsx[(((idx-iiterationsu)+88*(idy-jiterationsu))*(detectorXDim/2)+(xint-1))*3+2]=z;
		//__syncthreads();
void printMat(float*P,int uWP,int uHP){
	int i,j,contador=0;
	for(i=0;i<uHP;i++){
		contador++;
		printf("\n");
		for(j=0;j<uWP;j++){
			printf("%f ",P[i*uWP+j]);
__host__ void iteracaoealocagem(){
	//test input
	int xbin=0,ybin=0,zbin=0,xbinsize=1,ybinsize=1,zbinsize=0,angle=0,detectorXDim=2*1408,detectorYDim=2*1792,detectorZDim=60,projecoes=0;
	float xfocus=1408,yfocus=600,zfocus=60;
	cudaError_t status;
	int iiterationsu=iiterations;
	int jiterationsu=jiterations;
	//	3584/32=112 => 112/8= 14		1408/16=88 => 88/8=11
	dim3 dimGrid(11,14);//para um bloco do detector de 88x112, isto faz com que o maximo de intersectionsx seja 150Mb e intersectionsy 400Mb
	dim3 dimBlock(8,8,1);
	//CPU ALLOCATION AND DEBUG
	float *intersectionsx_h=(float*)malloc(dimGrid.x*dimGrid.y*dimBlock.x*dimBlock.y*3*1408*sizeof(float));//166Mb
	if (intersectionsx_h == NULL)
		printf ( "!!!! host memory allocation error (interx)\n");
	//GPU ALLOCATION AND DEBUG
	float *intersectionsx_d;
	status=cudaMalloc((void**)&intersectionsx_d,dimGrid.x*dimGrid.y*dimBlock.x*dimBlock.y*3*1408*sizeof(float));
	if (status != cudaSuccess)
            printf ("!!!! device memory allocation error (interx)\n");
	//KERNEL CALL
	sysmat<<<dimGrid,dimBlock>>>(intersectionsx_d,xfocus,yfocus,zfocus, xbin, xbinsize,ybin,ybinsize,zbin,zbinsize,detectorXDim,detectorYDim,projecoes,detectorZDim,iiterationsu,jiterationsu,angle);
	//COPY GPU RESULTS TO CPU AND DEBUG
	status=cudaMemcpy(intersectionsx_h,intersectionsx_d,dimGrid.x*dimGrid.y*dimBlock.x*dimBlock.y*1408*3*sizeof(float),cudaMemcpyDeviceToHost);
            printf ("!!!! could not retrieve from GPU (interx)\n");
	printf("\n Matriz de intersecoes de x \n");
	printMat(intersectionsx_h,3,1046500);
	//FREE MEMORY AND DEBUG
	status=cudaFree(intersectionsx_d);
		printf ("!!!! device memory free error (interx)\n");
	free(intersectionsx_h);
void print_func_attr(struct cudaFuncAttributes at)
        printf("Constant memory in bytes: %lu\n", at.constSizeBytes);
        printf("Local memory in bytes: %lu\n", at.localSizeBytes);
        printf("Max Thread per Block: %d\n", at.maxThreadsPerBlock);
        printf("Number of registers used: %d\n", at.numRegs);
        printf("Shared memory in bytes: %lu\n", at.sharedSizeBytes);
int main(){
	struct cudaFuncAttributes attr;
	cudaFuncGetAttributes(&attr, "_Z6sysmatPffffiiiiiiiiiiiii");
	print_func_attr(attr);
	iteracaoealocagem();
P.S This is the code for interx.cu, the other is almost the same, the only thing that changes is the for cycle inside the kernel
I guess i figured it out, if I pad the matrix with zeros, I believe it deals with the problem
