I managed to execute a pipeline that is configured to run ResNet18 on the DLA core 0 (property settings: enable-dla=1 & use-dla-core=0 for Gst-nvinfer) successfully without error.
But, when I tried to execute the same pipeline again in another process (while the first instance of that pipeline still running), I encountered below error:
ERROR: [TRT]: 1: [nvdlaUtils.cpp::deserialize::153] Error Code 1: DLA (NvMediaDlaInit : Init failed.)
ERROR: create TRT cuda executionContext failed
Then, I terminated the first instance and execute pipeline again. The pipeline is executed successfully.
Is this a limitation that one DLA core can be used in one pipeline at a time? Or, there is additional configuration is needed in order to have 2 pipelines shares a same DLA core?
We can deploy two pipelines on the DLA without issue.
Below are our configure files that are modified from the source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt and config_infer_primary_nano.txt for your reference:
diff --git a/config_infer_primary_nano.txt b/config_infer_primary_nano.txt
index e2cd097..0fba437 100644
--- a/config_infer_primary_nano.txt
+++ b/config_infer_primary_nano.txt
@@ -62,10 +62,12 @@ gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector_Nano/resnet10.caffemodel
proto-file=../../models/Primary_Detector_Nano/resnet10.prototxt
-model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine
+model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b1_dla0_fp16.engine
labelfile-path=../../models/Primary_Detector_Nano/labels.txt
-batch-size=8
+batch-size=1
process-mode=1
+enable-dla=1
+use-dla-core=0
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
diff --git a/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt b/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt
index 8020f3d..93f9876 100644
--- a/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt
+++ b/source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx1.txt
@@ -26,9 +26,9 @@ perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
-enable=1
-rows=4
-columns=2
+enable=0
+rows=1
+columns=1
width=1280
height=720
gpu-id=0
@@ -44,7 +44,7 @@ enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
-num-sources=8
+num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
@@ -53,7 +53,7 @@ gpu-id=0
cudadec-memtype=0
[sink0]
-enable=1
+enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
@@ -64,7 +64,7 @@ nvbuf-memory-type=0
overlay-id=1
[sink1]
-enable=0
+enable=1
type=3
#1=mp4 2=mkv
container=1
@@ -78,7 +78,7 @@ bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
-output-file=out.mp4
+output-file=/home/nvidia/out.mp4
source-id=0
[sink2]
@@ -117,7 +117,7 @@ nvbuf-memory-type=0
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
-batch-size=8
+batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
@@ -138,8 +138,8 @@ nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
-batch-size=8
+batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
@@ -151,7 +151,7 @@ nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
-enable=1
+enable=0
# For NvDCF and DeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=640
tracker-height=384
@@ -167,4 +167,4 @@ enable-past-frame=1
display-tracking-id=1
[tests]
-file-loop=0
+file-loop=1
