Hello Alexx,
Completely agree with your analysis.
I had encountered the same problem with a 1080x720@50 configuration.
[ 197.060514] vi 54080000.vi: tegra_channel_error_status:error 4000 frame 2
[ 197.074007] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00004015
This configuration requires only one CSI line.
To solve it I forced the configuration to use a single line.
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
status = "okay";
reg = <0>;
tc358743_vi_in1: endpoint {
status = "okay";
port-index = <0>; // CSI-A
bus-width = <2>;
remote-endpoint = <&tc358743_csi_out0>;
csi_base: nvcsi {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
status = "okay";
reg = <0>;
tc358743_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&tc358743_out1>;
csi_chan0_port1: port@1 {
status = "okay";
reg = <1>;
tc358743_csi_out0: endpoint@1 {
remote-endpoint = <&tc358743_vi_in1>;
hdmi27m_osc: hdmi-osc {
compatible = "fixed-clock";
clock-output-names = "hdmi-osc";
clock-frequency = <27000000>;
#clock-cells = <0>;
i2c@546c0000 {
status = "okay";
#size-cells = <0>;
tc358743@0f {
status = "okay";
compatible = "toshiba,tc358743";
reg = <0x0f>;
/* External clock */
clocks = <&hdmi27m_osc>;
clock-names = "refclk";
/*reset-gpios = <&gpio TEGRA_GPIO(S, 7) 0>;*/
/* Physical dimensions of sensor */
physical_w = "4.713";
physical_h = "3.494";
/* Sensor Model */
sensor_model ="tc358743";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
// =============== v4l2_of_endpoint =============== //
tc358743_out1: endpoint {
port-index = <0>; /* CSI A */
bus-width = <2>;
phy_mode = "DPHY";
data-lanes = <1 2>;
clock-lanes = <0>;
clock-noncontinuous;
link-frequencies = /bits/ 64 <297000000>; // 297000000/486000000/594000000
remote-endpoint = <&tc358743_csi_in0>;
