Multiple RGBD cameras for Isaac ROS VSLAM
Is it possible to run Isaac ROS VSLAM with multiple RGBD cameras? I saw that the localization works pretty decently with multiple stereo infra red cameras or stereo RGB cameras, but what about RGBD (RGB Depth) cameras? Does it support this type of multi-camera tracking?
Hello @andreivalean20,
If you mean using the RGB image and depth map from each of multiple RGB-D cameras together for tracking, this is not currently exposed by the Isaac ROS 5.0 wrapper, which provides only one depth input.
Newer cuVSLAM versions provide an experimental Multisensor mode for multiple RGB-D cameras. You can evaluate it through this official PyCuVSLAM example, which demonstrates two RGB-D cameras with or without an IMU. Please follow the example’s requirements, including aligning each depth image with its corresponding RGB image. This mode is experimental and currently supports pinhole cameras.
Isaac ROS 5.0 uses cuVSLAM 15.0.0, so using this newer capability would require you to upgrade the library and extend the ROS wrapper as a custom integration.
Thank you for your reply! This is exactly what I meant, yes.
Do you happen to know when a proper implementation will become available, or what libraries I could use to contribute to the project so I can make an implementation myself?
There’s no public release date for multi-RGB-D support in the Isaac ROS wrapper yet.
The core feature already exists in cuVSLAM, so you can build it yourself.
Libraries you’ll need:
Here are the steps for your reference :
  1. Test your cameras outside ROS. Install the PyCuVSLAM wheel. You need a CUDA toolkit matching the wheel tag (cu12 or cu13). Then run the multisensor example with your own data: cuVSLAM/examples/multisensor at v17.0.1 · nvidia-isaac/cuVSLAM · GitHub
  2. Fork isaac_ros_visual_slam and point it at cuVSLAM v17.0.1.
    The wrapper currently builds it with -DUSE_CUNLS=OFF, switch that to ON.
  3. Extend the wrapper:
    • subscribe to one depth topic per camera.
    • sync each depth image with its RGB image.
    • pass them all to the tracker in Multisensor mode.
  4. If you would like to contribute upstream, open a GitHub issue describing your setup and
    planned changes first. Then submit a PR with signed-off commits, following CONTRIBUTING.md.
Note: Multisensor mode is experimental. It currently supports only pinhole cameras, and each RGB image needs its own aligned depth image.
