Hi all,
I’m actually doing a research to enable multiple video sources (V4L2 subdevices) in one device driver instance but there is not information for this kind of support and I will appreciate any clarification on how the capture subsystem works and possible limitations/issues for this case.
I already asked this some time ago (link) but the answer received didn’t mention specific limitations or issues on the capture subsystem, only assumed possible limitation on V4L2 framework but it shouldn’t be a limitation for V4L2.
So, I’m looking for possible limitations on the capture subsystem or possible issues on how the Xavier links elements. I’ve been checking the kernel’s source code and I just want to provide my current understanding, any clarification to resolve doubts will be appreciated.
Just to start, this is what I understand for the standard links between capture subsystem and V4L2 subdevice within a device driver for a camera:
i2c@xxxx{
device@xx {
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
dev_out: endpoint {
port-index = <0>;
bus-width = <2>;
vc-id = <1>;
remote-endpoint = <&csi_in0>;
host1x {
csi_base: nvcsi@15a00000 {
#address-cells = <0x1>;
#size-cells = <0x0>;
num-channels = <6>;
channel@0 {
reg = <0x0>;
status = "okay";
ports {
port@0 {
reg = <0>;
status = "okay";
endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&dev_out>;
port@1 {
reg = <1>;
status = "okay";
endpoint@1 {
status = "okay";
remote-endpoint = <&vi_in0>;
vi_base: vi@15c10000 {
num-channels = <6>;
ports {
port@0 {
reg = <0>;
status = "okay";
vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
vc-id = <1>;
remote-endpoint = <&csi_out0>;
In the device-tree, the V4L2 subdevice within the device driver is linked to a NVCSI channel then the NVCSI channel is linked to the VI capture subsystem, the vi output creates the video node /dev/videoX that we use to get the final video frames on the user space.
This is the common link and usage between device driver, NVCSI and VI. This pattern is replicated in the camera drivers on the kernel source code.
Using media-ctl to graph the links between element in the capture pipeline, the graph looks like this:
So, we have a v4l-subdev created within the device driver (ap1302), this subdev is linked to a nvcsi channel and then the final connection is a VI node called vi -output which also created the /dev/video0 used from user-space.
Using more driver instances we can see the same pattern: V4L2 subdev driver → NVCSI channel → VI output.
So, here is my first question:
- Creating more subdevices withing a single device driver only the first one created and registered with v4l2_async_register_subdev is displayed on the graph, so it looks like the kernel only expects one subdevice per driver instance, is this statement correct? if so, are there issues to handle multiple subdevices?
Since the connection from the device driver to NVCSI was done in the ports section (in all cases from sample code the camera device driver only enabled a port0 I assume this is the link from subdevice on device driver to NVCSI) so I tried to enable a second port in the device node definition to a second NVCSI/VI channels just as used with a single subdevice:
i2c@xxxx{
device@xx {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
dev_out: endpoint {
port-index = <0>;
bus-width = <2>;
vc-id = <1>;
port@1 {
reg = <1>;
dev_out1: endpoint {
port-index = <0>;
bus-width = <2>;
vc-id = <0>;
remote-endpoint = <&csi_in1>;
host1x {
num-channels = <6>;
channel@0 {
reg = <0x0>;
status = "okay";
ports {
port@0 {
reg = <0>;
status = "okay";
endpoint@0 {
status = "okay";
port-index = <0>;
bus-width = <2>;
port@1 {
reg = <1>;
status = "okay";
endpoint@1 {
status = "okay";
channel@1 {
reg = <0x1>;
status = "okay";
ports {
port@0 {
reg = <0>;
status = "okay";
endpoint@2 {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&dev_out1>;
port@1 {
reg = <1>;
status = "okay";
endpoint@3 {
status = "okay";
remote-endpoint = <&vi_in1>;
num-channels = <6>;
ports {
port@0 {
reg = <0>;
status = "okay";
vi_in0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
vc-id = <1>;
port@1 {
reg = <1>;
status = "okay";
vi_in1: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
vc-id = <0>;
remote-endpoint = <&csi_out1>;
I tried to use the same approach on device-tree definition to link a single device driver node to 2 NVCSI/VI channels:
Standard link:
V4L2 subdevice (device driver) -> NVCSI -> VI_output
What I expected in this second device definition
V4L2 subdevice (device driver) -> NVCSI channel0 -> VI_output0
|-> NVCSI channel1 -> VI_output1
but I received an error from the kernel
tegra194-vi5 15c10000.vi: invalid port number 1 on /i2c@3180000/ap1302@3C
So, it looks like the module that parses the device tree to create the links between elements only expects one port per driver instance.
- My second question here: is this case failing due to hardware issues or limitation on the capture subsystem? it looks to me that this is a limitation in the module that parses the device tree, but not really a limitation on the hardware or capture subsystem.
In fact, the file that reports the error is graph.c and it is created by Nvidia so I suppose this issue is an unexpected case but can be patched in the kernel to support multiple V4L2 subdevice per driver instance. Any clarification in how Nvidia enables the different elements in the capture subsystem to support multiple subdevices will be appreciated.
The subdevices, NVCSI and VI links are more complex and it looks that more of the work is done in the graph.c file, I’m checking the code to have a better understanding in order to enable 2 subdevices per driver instance as described in the second device-tree. I will provide an update for the new findings/questions after checking how the links are created.
Thanks in advance for any extra information that helps to have a better understanding on how the capture subsystem works, specially to enable multiple subdevices.
