Hi everyone,
I am a beginner in cuda programming. Here is the problem statement, we have two arrays: The first array is an array of 0’s and 1’s (Let’s call it arr1). size of arr1 is 150 and it contains 10 binary numbers. length of each binary number in arr1 is 15.
The second array is an array of 0’s and 1’s (Let’s call it arr2). size of arr2 is 310 and it contains 10 binary numbers. length of each binary number in arr2 is 31.
What we want to do is to fill 2 arrays (call them xor1 and xor2). The size of xor1 will be 135, and size of xor2 will be 279. xor1 and xor2 are filled according to the following code (C++):
for(int i = 0; i < 9; i++)
for(int j = 0; j < 15; j++)
xor1[i * 15 + j] = arr1[i * 15 + j] ^ arr1[(i+1) * 15 + j];
for(int j = 0; j < 31; j++)
xor2[i * 31 + j] = arr2[i * 31 + j] ^ arr2[(i+1) * 31 + j];
What is the efficient way of implementing this in cuda? Is there any way to calculate xor1 and xor2 at the same time?
Thank you for your time in advance
