Multisrc camera libargus, not passing both images downstream deepstream 6.1
I am refactoring a gstreamer element that takes two CSI cameras using the argus lib from nvidia - the refactor is from the old nvbuf_utils to NvUtils, https://developer.nvidia.com/sites/default/files/akamai/embedded/nvbuf_utils_to_nvutils_migration_guide.pdf .
The element itself consumes > 2 CSI cameras, syncs the frames and sends them to the src pad of the element. In the original element, the following pipelines respectively output 1 video with 1 frame and 1 video with two frames side-by-side.
Single Pipeline:
gst-launch-1.0 -v nvarguscameras sensors='0 1' silent=false sync-threshold=16700000 ! "video/x-raw(memory:NVMM),format=(string)NV12,width=(int)1920,height=(int)1080,framerate=(fraction)30/1" ! nvvideoconvert ! nvv4l2h264enc ! h264parse !  filesink location=single.mp4 -e
Double Pipeline:
gst-launch-1.0 -v nvarguscameras master-sensor=0 sensors='0 1' sync-threshold=16700000 silent=false ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=(string)NV12,width=(int)1920,height=(int)1080,framerate=(fraction)30/1" ! nvmultistreamtiler width=3840 height=1080 rows= columns=2 ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=(string)I420' ! nvv4l2h264enc bitrate=800 ! h264parse ! qtmux ! filesink location="test.mp4" -e
In hte original implementation, the API used the NvBufferTransform to perform some modification on the frame. However, this time i just want to pass the frames through.
For reference the frameInfo is struct that holds the width,height and fd of the buffer from another thread.
Original implementation:
      // copy buffer surface
      GST_DEBUG_OBJECT (src, "consumer prepare buffer surfaces");
      GstMapInfo outmap = GST_MAP_INFO_INIT;
      gst_buffer_map (buffer, &outmap, GST_MAP_WRITE);
      NvBufSurface* surf = (NvBufSurface*) outmap.data;
      assert(surf->batchSize == src->sensors_num);
      assert(frames_buffer->len <= src->sensors_num);
      surf->numFilled = 0;
      for (int i = 0; i < frames_buffer->len; i++) {
        GST_DEBUG_OBJECT (src, "consumer fill buffer surface %d", i);
        NvArgusFrameInfo *frameInfo = g_array_index(frames_buffer, NvArgusFrameInfo*, i);
        gint retn = NvBufferTransform (frameInfo->fd, (gint)surf->surfaceList[i].bufferDesc, &src->transform_params);
        if (retn != 0) {
          GST_ERROR_OBJECT(src, "consumer NvBufferTransform Failed");
          break;
        surf->numFilled++;
        // attach frame meta
        NvDsFrameMeta *frame_meta = nvds_acquire_frame_meta_from_pool(batch_meta);
        frame_meta->pad_index = i;
        frame_meta->batch_id = i;
        frame_meta->frame_num = frameInfo->frameNum;
        frame_meta->buf_pts = frameInfo->frameTime;
        frame_meta->ntp_timestamp = 0;
        frame_meta->source_id = src->sensors[i];
        frame_meta->num_surfaces_per_frame = 1;
        frame_meta->source_frame_width = frameInfo->width;
        frame_meta->source_frame_height = frameInfo->height;
        nvds_add_frame_meta_to_batch(batch_meta, frame_meta);
      gst_buffer_unmap (buffer, &outmap);
      if (surf->numFilled != frames_buffer->len ||
          batch_meta->num_frames_in_batch != frames_buffer->len) {
        GST_ERROR_OBJECT(src, "consumer failed fill nvmm buffer");
        break;
Updated Implementation:
      if (!gst_buffer_map (buffer, &outmap, GST_MAP_WRITE)){
        g_print ("Error: Failed to map gst buffer\n");
        break;
        surf->surfaceList[i].bufferDesc = frameInfo->fd;
        surf->numFilled++;
        break;
The single pipeline works fine, i can get the video of one frame, but when i try the second pipeline i just get a green video. Any suggestions here guys ?
I tried using the NvBufSurfTransform instead of just passing the fd to the NvBufSurface, but this yields the same results.
Both frames are available in my updated code as i can hard code in the for loop to choose which one is present in the single video pipeline.
• DeepStream Version
• TensorRT Version
why no use nvarguscamerasrc we already have? could you share why do you want to refactor that gstreamer element? will you need to do model inference?
we recommend to use the following command to achieve this function, It works fine.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 num-buffers=200 ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! nvvideoconvert ! nvmultistreamtiler width=1920 height=1080 ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! video/x-raw\(memory:NVMM\),format=I420 ! nvv4l2h264enc bitrate=1000000 ! filesink location=test.264 nvarguscamerasrc sensor-id=1 num-buffers=200 ! m.sink_1
