Mutual interference during camera reinitialization
Test Machine: Jetson ORIN NX
Test Software Version: JP6.2.2GA
Camera Connection Scheme: MAX96712 connected to four SHW3G cameras
Test Procedure:
Use Senyun official shw3g.ko, modify the source code to support the reinit operation (detailed steps: after manually controlling the power supply of a single camera via I2C at the upper layer, call reinit to initialize the serializer and sensor of this individual camera; no operations will be performed on the deserializer).
When acquiring images from one camera while performing the reinit operation on another camera: if using v4l2, the camera currently capturing images will drop frames directly; if using argus, the image capture application will throw an error and terminate immediately.
dmesg.txt (6.2 KB)
gst-launch.txt (6.7 KB)
nvargus.txt (2.0 KB)
If each camera working well individually the root cause could be the MAX96712 REG config.
I have checked the reinit flow (the hardware powers down and resets the camera independently, initializes the corresponding ser and sensor, and does not rewrite dser)
When the camera is not running, reinit can normally restore the camera to normal.
However, this issue affects image capture from another camera.
Do you have any ideas to fix this?
I would suggest consult with Maxim to figure out the problem.
