make[5]: Entering directory `/home/user/src/mvapich2-1.8a2/src/pm/hydra/tools/topo/hwloc/hwloc/src'
CC topology.lo
CC traversal.lo
CC distances.lo
PGC-S-0039-Use of undeclared variable __FLT_MAX__ (distances.c: 325)
PGC-S-0039-Use of undeclared variable __FLT_MIN__ (distances.c: 325)
PGC/x86-64 Linux 12.2-0: compilation completed with severe errors
It’s like it’s not seeing the include directory for PGI 12.2 which has float.h.
When I run pgcc -show:
(203) > pgcc -show | grep -i include
pgcc-Warning-No files to process
COMPINCDIR Compiler include subdirectory =include
DEFCPPINC =/opt/pgi/linux86-64/12.2/include/CC
DEFSTDINC =/opt/pgi/linux86-64/12.2/include /usr/local/include /usr/lib/gcc/x86_64-redhat-linux/4.1.2/include /usr/lib/gcc/x86_64-redhat-linux/4.1.2/include /usr/include
DRYSTDINC Display standard include directories and exit
GCCINC =/usr/lib/gcc/x86_64-redhat-linux/4.1.2/include
GPPDIR =/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2 /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/x86_64-redhat-linux /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/backward
I8STORAGE Indicates whether to include pgfi8st.o object
MPI1INC =/opt/pgi/linux86-64/2012/mpi/mpich/include
MPIHPINC =/opt/hpmpi/include
MPILIBINC =/opt/pgi/linux86-64/2012/mpi/mpich/include
/opt/pgi/linux86-64/12.2/include is in DEFSTDINC.
Is there an extra flag I need to pass? Or something slightly off with the 12.2 install?
So, I tried to configure with an additional CPPFLAGS=-D_GNU_SOURCE, but the make still fails (maybe hwloc manipulates _GNU_SOURCE as well).
Any ideas on how to get around this? Obviously I could remove the ifndef in float.h, but I’m assuming that’s there for a good reason (I tried looking at the TPRs, but there aren’t any publicly reported for 12.2 yet.)
I encountered the same problem. If you look closer at float.h you’ll see it checks if_GNU_SOURCE is not defined, so defining it won’t do any good. My workaround was to wrap the include as follows:
The “_GNU_SOURCE” line was added for our new g++ compatibility feature in the our C++ compiler (i.e. the pgc++ driver, or pgcpp --gnu). Though, our engineers may broken something on the C side because of it. Let me investigate and get back to you.
Thank you for the quick reply. I came here considering submitting a problem report but first searched the forums to see if anyone else encountered the same issue.
I found that the limits.h file already had your suggested #if statement. It was only float.h that required correction. That solved my problems building MVAPICH2, but OpenMPI is having related problems. In the C++ framework, I am getting:
"/opt/pgi/linux86-64/12.2/include/CC/stl/_limits.h", line 153: error:
identifier "__CHAR_BIT__" is undefined
((int)((sizeof(_Int) * (CHAR_BIT))) - ((__imin == 0) ? 0 : 1))
on a C++ file being compiled with pgCC. I am guessing in this case that __cplusplus will be defined and thus the CHAR_BIT macro in limits.h is getting #if’ed out. I don’t have time to debug this the rest of the day but will get back to it next week.
For what’s it’s worth. I’m running into close but similar issue related to float.h vars not being found when compiling OpenMPI in OFED 1.5.3.2 using PGI v12.2
libtool: compile: pgcc -DHAVE_CONFIG_H -I. -I../../opal/include -I../../orte/include -I../../ompi/include -I../../opal/mca/paffinity/linux/plpa/src/libplpa -I../.. -D_REENTRANT -O -DNDEBUG -c cmd_line.c -fpic -DPIC -o .libs/cmd_line.o
PGC-S-0039-Use of undeclared variable __LDBL_MANT_DIG__ (../../opal/util/arch.h: 271)
PGC-S-0039-Use of undeclared variable __LDBL_MAX_EXP__ (arch.c: 70)
I’m sorta new to PGI so when will 12.3 be available or is there a way to get beta release or hot fix?
Encountered the same issue with MPICH2 1.4.1p1. It would be nice if this was posted on the MPICH page ( https://www.pgroup.com/resources/tips.htm#MPICH). It would have saved me some time and head banging.
