My computer is WIN11 system, currently can not install issaac sim4.5 version, the following is the current error information. Driver removal tested se
Hi, thanks for sharing the error details and screenshots. To help diagnose the issue further, could you please provide the full Isaac Sim installation log as a .txt file? This log will contain more detailed error information that is essential for troubleshooting.
Hello! Where is this sim 4.5 installation log? Please let me know. Thank you
新建 文本文档 (5).txt (33.1 KB)
Here is the txt
2025-04-17 05:02:58 [1,815ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-04-17 05:02:58 [1,817ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-04-17 05:02:58 [1,818ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-04-17 05:02:58 [1,822ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-04-17 05:02:58 [1,822ms] [Error] [gpu.foundation.plugin] Multiple Installable Client Drivers (ICDs) are found for the same GPU on the system. This causes the same GPU to be reported multiple times by more than one driver and leads to instability or crash.
For Windows, a clean driver reinstallation may be required. It might also happen after connecting with some certain remote desktop applications.
| Driver Version: 566.24        | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA RTX 2000 Ada Generation.. |        |     | 7960    MB | 10de      | b5b5600f.. |
|     |                                  |        |     |            | 28b8      | 106eb739.. |
|     |                                  |        |     |            | 1         |            |
| 1   | Intel(R) Iris(R) Xe Graphics     |        |     | 16200   MB | 8086      | 815d0100.. |
|     |                                  |        |     |            | a7a0      | 8680a0a7.. |
|     |                                  |        |     |            | N/A       |            |
| 2   | Intel(R) Iris(R) Xe Graphics     |        |     | 16200   MB | 8086      | 41d10100.. |
|     |                                  |        |     |            | a7a0      | 8680a0a7.. |
|     |                                  |        |     |            | N/A       |            |
| OS: Windows 11 Home China, Version: 10.0 (23H2), Build: 22631, Kernel: 10.0.22621.5185
| Processor: 13th Gen Intel(R) Core(TM) i7-13700H
| Cores: 14 | Logical Cores: 20
| Total Memory (MB): 32400 | Free Memory: 17506
| Total Page/Swap (MB): 37264 | Free Page/Swap: 14865
Could you refer to Cannot Run Isaac Sim using Standalone Workflow - #5 by 23and1 and try disabling the Intel GPU to see if it resolves the issue?
