My ConnectX does not send or receive ethernet packets anymore
I have a Mellanox ConnectX EN 10G (mt26448)
that I use in a Proxmox (Debian) server. It had bios version 2.7. With that bios it gave a lot of “command 0x54 failed” errors. I solved upgrading it to bios 2.9.1000
After reboot I have seen enp7s0 and enp7s0d1 devices but I was unable to ping other servers.
I have done the command service mst start and, incredibly, I was able to ping.
Now I have upgraded kernel and this trick does not work anymore nor it works going back to older kernel.
I suppose the card is not broken but it is only a software configuration problem.
Unfortunately I cannot change easily the card because the server is in an housing far away.
I hope I can reenable ports via software.
Can you help me?
Thanks,
Mario
Looking at ethtool output I see this:
Settings for enp7s0:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: No
Advertised link modes: 10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: No
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000014 (20)
link ifdown
Link detected: yes
The card says link ifdown. The card is attached using DAC, not FIBRE.
Hello Mario -
lspci | Grep Mellanox # get bus:dev.func
NOTE: Use your device (bus:dev.func) in place of “85:00.0”
lspci -s 85:00.0 -xxxvvv
cat /etc/release
uname -r
mlxlink -d 85:00.0 -c -e --show_fec -m --show_serdes_tx --show_device
mlxlink -d 85:00.0
mlxlink -d 85:00.0 --show_counters
mlxlink -d mlx5_0 -p 1 -emc
ethtool -i
get fw version from the nic:
ethtool
ethtool -m
~Steve
Many thanks!
Here it is:
07:00.0 Ethernet controller: Mellanox Technologies MT26448 [ConnectX EN 10GigE, PCIe 2.0 5GT/s] (rev a0)
Subsystem: Mellanox Technologies MT26448 [ConnectX EN 10GigE, PCIe 2.0 5GT/s]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 37
NUMA node: 0
Region 0: Memory at df300000 (64-bit, non-prefetchable) [size=1M]
Region 2: Memory at d5000000 (64-bit, prefetchable) [size=8M]
Expansion ROM at df200000 [disabled] [size=1M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] Vital Product Data
Product Name: Hawk Dual Port
Read-only fields:
[PN] Part number: 59Y1905
[EC] Engineering changes: A1
[SN] Serial number: YK50200000EB
[V0] Vendor specific: PCIe Gen2 x8
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[V1] Vendor specific: N/A
[YA] Asset tag: N/A
[RW] Read-write area: 106 byte(s) free
End
Capabilities: [9c] MSI-X: Enable+ Count=128 Masked-
Vector table: BAR=0 offset=0007c000
PBA: BAR=0 offset=0007d000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported+
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #8, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x8, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Kernel driver in use: mlx4_core
Kernel modules: mlx4_core
00: b3a0
10: 04 00 30 df0c 00 00 d5
20:00b3 15 50 67
30: 00 00 20 df00 0f 01 00 00
40:00 03 9c ff 7f
50:00 14 00 0f 00 90 01 a0 00
60:8e 64 10 2ef4 03 08
70:
80:1f
90:007f 80
a0: 00 c0 07 00 00 d08a
b0:0000
c0:0000
d0:0000
e0:0000
f0:0000
RETTY_NAME=“Debian GNU/Linux 9 (stretch)”
NAME=“Debian GNU/Linux”
VERSION_ID=“9”
VERSION=“9 (stretch)”
ID=debian
HOME_URL=“https://www.debian.org/
SUPPORT_URL=“Debian -- User Support
BUG_REPORT_URL=“https://bugs.debian.org/
4.15.18-11-pve
Please note it is a Proxmox 5.3 (Debian based)
Hello Mario -
the ethtool outputs are missing:
ethtool -i
ethtool
ethtool -m
Thanks - steve
Sorry I did not see part of your reply.
Anyway the problem is that I had to install mft 3.8.0 because it is the only one that yet compile with recente kernels and that recognizes my card. And mft 3.8.0 does not have mlxlink command.
Here is the data:
flint -d /dev/mst/mt26448_pciconf0 query
Image type: FS2
FW Version: 2.9.1000
Rom Info: type=PXE version=1.5.5 devid=26448 proto=ETH
Device ID: 26448
Description: Port1 Port2
MACs: 0002c90827d8 0002c90827d9
VSD:
PSID: IBM0050000010
ethtool -i enp7s0
driver: mlx4_en
version: 4.5-1.0.1
firmware-version: 2.9.1000
expansion-rom-version:
bus-info: 0000:07:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: yes
ethtool enp7s0
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Supports Wake-on: d
Wake-on: d
link ifdown
Link detected: yes
ethtool -m enp7s0
Cannot get module EEPROM information: Input/output error
Thanks again,
Mario
Hello Mario -
You would have to take this with IBM support as the NIC is flashed with IBM FW.
PSID: IBM0050000010
I hope this helps…
~Steve
I understand I cannot receive support from you because it is an IBM OEM card. But I want to share what I have discovered: if, after reboot, I detach and reattach cables it starts working.
Have you a little hint to share with me about this
