I’m new to cuda programming, and I’m facing a peculiar problem while running my code on GPU. The code runs fine the first time. But the second time I run it (i.e. within 20-30 mins ), it stalls indefinitely. If I run it after 30 mins, it again runs fine. This occurs even when I I make no changes in the code between two runs, and even when there are no other users on the machine.
The stall occurs at a structure declaration:
cudaMalloc( (void **)&(d_cuda), sizeof(gpuVars));
The structure definition is:
typedef struct _gpuVars gpuVars;
struct _gpuVars {
int nvol;
int npts;
int nbel;
double fluid_Lx, fluid_Ly, fluid_Lz;
double fluid_nx, fluid_ny, fluid_nz;
double fluid_delta;
int fluid_wallbc;
int fluid_xzbc;
int fluid_nprop;
Any help will be appreciated – let me know if you need more information
Thanks in advance
Amitabh
