Here is the log;
flash dtb log.txt (15.8 KB)
I am very sad that my Ethernet Network is unavailable, and it is just a RJ45 con. I use it well on TX2.
I also have impedance control in my PCB.
Here is the log;
Oh. I found the problem. You are using the wrong module.
You are not using the b01 module.
My Carrier Board will work well if I try the b01 moudle ?
Yes, only the B01 module can work for custom carrier board. Our product design guide is also for b01 module.
Hi, WayneWWW.
My carrier Board works well after I use the BO1 module.
