zl.he
December 12, 2024, 6:13pm
1
My device is AGX Orin 32GB.
Host machine is x86, ubuntu 22.04
First time, it is ok and there is no problem.
Second time, I only can flash OS. and for the SDK components, it shows cannot detect a board.
Third time, I even cannot flash the OS! It shows
error
flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/hezhili/.nvsdk
rpcbind: another rpcbind is already running. Aborting.
zl.he
December 12, 2024, 6:14pm
2
Then for the second time, I did nothing. I installed jetpack in the flashed Orin.
But for the third time, I have to solve it! refer to Not able to flash Jetson Orin Nano SDK manager
zl.he
December 12, 2024, 6:16pm
3
My solution:
(1) Change to another USB port.
(2) remove ~/.nvsdkm/
(3) remove `/etc/exports
And re-flash. and it works! No problem again!
zl.he
December 12, 2024, 6:19pm
4
I want to mention, for the second time, I tried use Ethernet:
(1) choose Ethernet
(2) make host PC and Orin connect to a same wifi
(3) ping Orin ip and works
(4) change the default ip to the Orin ip
But ,
It doenst work!
zl.he
December 12, 2024, 6:22pm
5
Solve the two problems I met at the second and third time.
If you also met the same problems, it is deserved to have a try.
kayccc
December 12, 2024, 11:34pm
6
Thanks for your sharing to the community!
system
Closed
December 26, 2024, 11:35pm
7
