My GB10 MSI cannot connect to WiFi and Wired LAN during initial setup
My MSI GB10 is not to my WiFi network ( SSID with password, without password, and mobile phone hotspot) .
I tried to connect it both via the initial WiFi setup and by monitor
I already connected to wired LAN before plugging it in, but it’s still not working. (I already made sure that it got an IP via DHCP.)
Please give me some advice.
I have been stuck on the same step of the installation too, the solution for me was found in Setup Wizard loop - #8 by sjug
Are you worried about losing the MSI specific drivers or customizations by applying the NVIDIA recovery image? I have the same issue on 2x brand new Acer GN100… they want me to ship back for repair even though I proved it’s not a hardware issue! ugh.
In my case, I used the patched NVIDIA recovery image as a workaround to get past the broken OOBE connectivity check. Recovery completed, setup finished, updates installed and I can now boot into the Ubuntu GUI normally. So on my MSI unit, I did not hit any obvious loss of functionality after recovery. That said, I would still treat it as an unofficial workaround. I am also waiting on MSI response to hopefully provide there own.
I can confirm the same worked for my Acer Veriton GN100 DGX Spark machines. They are both online, no overt issues that I can see. Thanks for the quick turn around @sjug - not being able to use $$$ machines out of the box would suck :)
I found newly OS from MSI (2026-03-04).
  1. MD5: 82f854bffd013e165ba8848042bc0a0f
  2. Release note:
  • ConnectX-7 Hot-Plug Power Saving (up to ~18W reduction: 19W → 1W)
  • Bluetooth Audio Support
    - Added UEFI BIOS-Level Control to Disable Wi-Fi and Bluetooth <<<<< this might solve our problem.
  • Upgraded to Linux Kernel 6.17
  1. The BSP version must be paired with EC9310N1MSI.40170.bin and GOP 9000B90.”
https://ipc.msi.com/product_download/Industrial-Computer-Box-PC/AI-Supercomputer/EdgeXpert-MS-C931
