I have the following problem with my GPU
Is this actually an Xavier NX? If so, then you need to post it here in the NX forum:
https://forums.developer.nvidia.com/c/agx-autonomous-machines/jetson-embedded-systems/jetson-xavier-nx/258
Additionally, nobody will know what the actual problem is unless you post more information. Example:
- Is this a dev kit with the SD card, or is this an eMMC model?
- If you used an SD card image, which one?
- Did you ever flash with JetPack/SDK Manager (there is memory on the NX itself for SD card models)?
- If you can, then post a serial console log. This URL explains (note that the Nano and NX have the same instructions):
https://www.jetsonhacks.com/2019/04/19/jetson-nano-serial-console/
…but do put that information in the NX forum and not the Nano forum.
