![Y$02SHA8_0VG)(@G3DRLTG
Based on the output you have provided, the ibdump utility is active and listening. There is no indication of an application running alongside the ibdump utility.
For more information on utilization of the ibdump utility, please see the following Community Article:
https://community.mellanox.com/s/article/MLNX2-117-2032kn
Please also ensure that ibdump is not run from the same port of the Subnet Manager as there is a known issue regarding this scenario:
https://github.com/Mellanox/ibdump
ibdump may stop capturing packets when run on the same port of the Subnet Manager (E.G.: opensm). It is advised not to run the SM and ibdump on the same port.
If these conditions are met and you require further debugging, please open a case with our Support team. If you do not have a current support contract for your adapter, please reach out to the team at Networking-contracts@nvidia.com
Thank you,
-Nvidia Network Support
