Description
I finetuned Tensorflow Object Detection API CenterNet Resnet50 V1 FPN Keypoints 512x512 (models/tf2_detection_zoo.md at master · tensorflow/models · GitHub) and converted saved_model to a TF-TRT model. (FP16 precision)
But, converted model gets waning when inference and slow inference (a few sec/inference).
On the other hand, native saved_model is 0.03 sec/inference.
Warning types are two types.
2023-01-16 02:42:33.165965: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forPartitionedCall/TRTEngineOp_000_005 due to failure in verifying input shapes: Incorrect batch dimension, for PartitionedCall/TRTEngineOp_000_005: [[0,1], [0,1]]
2023-01-16 02:42:34.218372: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5907] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-16 02:42:34.218490: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for PartitionedCall/TRTEngineOp_000_002 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-10 10:37:03.250971: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger TensorRT encountered issues when converting weights between types and that could affect accuracy.
2023-01-10 10:37:03.251011: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger Check verbose logs for the list of affected weights.
2023-01-10 10:37:03.251019: W tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:83] TF-TRT Warning: DefaultLogger - 3 weights are affected by this issue: Detected finite FP32 values which would overflow in FP16 and converted them to the closest finite FP16 value.
Environment
TensorRT Version: 8.4.1
GPU Type: Tesla V100-PCIE-32GB
Nvidia Driver Version: 515.86.01
CUDA Version: 11.7
CUDNN Version:
Operating System + Version: Ubuntu 20.04
Python Version: 3.8.12
**TensorFlow Version **: tf-nightly 2.12.0.dev20230110
Steps To Reproduce
- Finetune CenterNet Resnet50 V1 FPN Keypoints 512x512 and convert pb file to saved_model.
- convert saved_model to a TF-TRT model by following script.
from tensorflow.python.compiler.tensorrt import trt_convert as trt
import numpy as np
num_runs = 1
SAVED_MODEL_DIR=f'./saved_model'
precision_mode = 'FP16'
conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS
conversion_params = conversion_params._replace(precision_mode=precision_mode)
# Instantiate the TF-TRT converter
converter = trt.TrtGraphConverterV2(
input_saved_model_dir=SAVED_MODEL_DIR,
conversion_params=conversion_params
# Convert the model into TRT compatible segments
trt_func = converter.convert()
converter.summary()
def my_input_fn():
for _ in range(num_runs):
inp1 = np.random.normal(size=(1, 512, 512, 3)).astype(np.uint8)
yield inp1
converter.build(input_fn=my_input_fn)
OUTPUT_SAVED_MODEL_DIR=f"./tftrt_saved_model_{precision_mode.lower()}"
converter.save(output_saved_model_dir=OUTPUT_SAVED_MODEL_DIR)
print(f'Done Converting to TF-TRT {precision_mode}')
This is convertion log.
$ python saved_model_to_tftrt.py
2023-01-22 09:14:48.206978: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 AVX512F AVX512_VNNI FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2023-01-22 09:14:48.339506: I tensorflow/core/util/port.cc:110] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable `TF_ENABLE_ONEDNN_OPTS=0`.
2023-01-22 09:14:48.384884: E tensorflow/tsl/lib/monitoring/collection_registry.cc:81] Cannot register 2 metrics with the same name: /tensorflow/core/bfc_allocator_delay
2023-01-22 09:14:50.037924: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 AVX512F AVX512_VNNI FMA
2023-01-22 09:14:50.949046: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1628] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 30941 MB memory: -> device: 0, name: Tesla V100-PCIE-32GB, pci bus id: 0000:af:00.0, compute capability: 7.0
2023-01-22 09:15:04.607141: I tensorflow/core/grappler/devices.cc:66] Number of eligible GPUs (core count >= 8, compute capability >= 0.0): 1
2023-01-22 09:15:04.607465: I tensorflow/core/grappler/clusters/single_machine.cc:358] Starting new session
2023-01-22 09:15:04.608681: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1628] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 30941 MB memory: -> device: 0, name: Tesla V100-PCIE-32GB, pci bus id: 0000:af:00.0, compute capability: 7.0
2023-01-22 09:15:11.025318: I tensorflow/core/grappler/devices.cc:66] Number of eligible GPUs (core count >= 8, compute capability >= 0.0): 1
2023-01-22 09:15:11.025509: I tensorflow/core/grappler/clusters/single_machine.cc:358] Starting new session
2023-01-22 09:15:11.026860: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1628] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 30941 MB memory: -> device: 0, name: Tesla V100-PCIE-32GB, pci bus id: 0000:af:00.0, compute capability: 7.0
2023-01-22 09:15:12.593974: W tensorflow/compiler/tf2tensorrt/convert/trt_optimization_pass.cc:186] Calibration with FP32 or FP16 is not implemented. Falling back to use_calibration = False.Note that the default value of use_calibration is True.
2023-01-22 09:15:12.979638: W tensorflow/compiler/tf2tensorrt/segment/segment.cc:962]
TensorRT unsupported/non-converted OP Report:
- Reshape -> 109x
- Cast -> 92x
- Pack -> 82x
- StridedSlice -> 60x
- Shape -> 39x
- Tile -> 30x
- Mul -> 29x
- GatherNd -> 28x
- Less -> 27x
- ExpandDims -> 26x
- AddV2 -> 22x
- Sub -> 22x
- Greater -> 21x
- Unpack -> 19x
- Select -> 15x
- GatherV2 -> 15x
- Fill -> 15x
- Placeholder -> 13x
- Identity -> 12x
- Transpose -> 10x
- GreaterEqual -> 10x
- TensorScatterAdd -> 10x
- EnsureShape -> 10x
- Switch -> 8x
- Merge -> 7x
- LogicalAnd -> 6x
- ConcatV2 -> 6x
- Enter -> 6x
- RealDiv -> 6x
- NextIteration -> 6x
- Where -> 5x
- ArgMin -> 5x
- Maximum -> 5x
- Equal -> 5x
- Round -> 4x
- Pad -> 3x
- Squeeze -> 2x
- ResizeBilinear -> 2x
- NoOp -> 2x
- TensorListReserve -> 2x
- TensorListSetItem -> 2x
- TensorListStack -> 2x
- Minimum -> 2x
- Exit -> 2x
- TensorListFromTensor -> 1x
- TensorListGetItem -> 1x
- LoopCond -> 1x
- Total nonconverted OPs: 807
- Total nonconverted OP Types: 47
For more information see https://docs.nvidia.com/deeplearning/frameworks/tf-trt-user-guide/index.html#supported-ops.
2023-01-22 09:15:13.451224: W tensorflow/compiler/tf2tensorrt/segment/segment.cc:1239] A total of 25 segments with at least minimum_segment_size=3 nodes have been found. TF-TRT will only convert the 20 largest segments. You can change this behavior by modifying the environment variable TF_TRT_MAX_ALLOWED_ENGINES=20
2023-01-22 09:15:13.459988: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:799] Number of TensorRT candidate segments: 20
2023-01-22 09:15:13.720193: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 0 consisting of 30 nodes by TRTEngineOp_000_000.
2023-01-22 09:15:13.720347: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 1 consisting of 5 nodes by TRTEngineOp_000_001.
2023-01-22 09:15:13.720412: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 2 consisting of 5 nodes by TRTEngineOp_000_002.
2023-01-22 09:15:13.720474: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 3 consisting of 5 nodes by TRTEngineOp_000_003.
2023-01-22 09:15:13.720535: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 4 consisting of 5 nodes by TRTEngineOp_000_004.
2023-01-22 09:15:13.720613: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 5 consisting of 5 nodes by TRTEngineOp_000_005.
2023-01-22 09:15:13.720671: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 6 consisting of 4 nodes by TRTEngineOp_000_006.
2023-01-22 09:15:13.720728: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 7 consisting of 4 nodes by TRTEngineOp_000_007.
2023-01-22 09:15:13.720782: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 8 consisting of 4 nodes by TRTEngineOp_000_008.
2023-01-22 09:15:13.720837: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 9 consisting of 4 nodes by TRTEngineOp_000_009.
2023-01-22 09:15:13.721089: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 10 consisting of 86 nodes by TRTEngineOp_000_010.
2023-01-22 09:15:13.721345: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 11 consisting of 39 nodes by TRTEngineOp_000_011.
2023-01-22 09:15:13.721534: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 12 consisting of 52 nodes by TRTEngineOp_000_012.
2023-01-22 09:15:13.721789: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 13 consisting of 794 nodes by TRTEngineOp_000_013.
2023-01-22 09:15:13.723540: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 14 consisting of 5 nodes by TRTEngineOp_000_014.
2023-01-22 09:15:13.723625: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 15 consisting of 7 nodes by TRTEngineOp_000_015.
2023-01-22 09:15:13.723706: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 16 consisting of 16 nodes by TRTEngineOp_000_016.
2023-01-22 09:15:13.723841: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 17 consisting of 31 nodes by TRTEngineOp_000_017.
2023-01-22 09:15:13.723937: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 18 consisting of 6 nodes by TRTEngineOp_000_018.
2023-01-22 09:15:13.724088: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:913] Replaced segment 19 consisting of 21 nodes by TRTEngineOp_000_019.
2023-01-22 09:15:16.326664: I tensorflow/core/common_runtime/executor.cc:1195] [/device:CPU:0] Executor start aborting: INVALID_ARGUMENT: You must feed a value for placeholder tensor 'unused_control_flow_input_8' with dtype int32 and shape [1]
[[{{node unused_control_flow_input_8}}]]
2023-01-22 09:15:16.338144: I tensorflow/core/common_runtime/executor.cc:1195] [/device:CPU:0] Executor start aborting: INVALID_ARGUMENT: You must feed a value for placeholder tensor 'unused_control_flow_input_14' with dtype int32 and shape [1]
[[{{node unused_control_flow_input_14}}]]
2023-01-22 09:15:16.340213: I tensorflow/core/common_runtime/executor.cc:1195] [/device:CPU:0] Executor start aborting: INVALID_ARGUMENT: You must feed a value for placeholder tensor 'unused_control_flow_input_16' with dtype int32 and shape [1]
[[{{node unused_control_flow_input_16}}]]
TRTEngineOP Name Device # Nodes # Inputs # Outputs Input DTypes Output Dtypes Input Shapes Output Shapes
TRTEngineOp_000_000 device:GPU:0 34 6 3 ['float16', 'f ... ['float32', 'f ... [[1, 1, 4], [1 ... [[1, 10, 4], [ ...
- AddV2: 5x
- Cast: 4x
- Const: 5x
- Maximum: 6x
- Minimum: 5x
- Mul: 3x
- Pack: 1x
- RealDiv: 1x
- Sub: 2x
- Unpack: 2x
TRTEngineOp_000_001 device:GPU:0 5 4 1 ['float16', 'f ... ['float32'] [[1, -1, 1], [ ... [[1, -1, -1, 2]]
- AddV2: 2x
- Cast: 2x
- Pack: 1x
TRTEngineOp_000_002 device:GPU:0 5 4 1 ['float16', 'f ... ['float32'] [[1, -1, 1], [ ... [[1, -1, -1, 2]]
- AddV2: 2x
- Cast: 2x
- Pack: 1x
TRTEngineOp_000_003 device:GPU:0 5 4 1 ['float16', 'f ... ['float32'] [[1, -1, 1], [ ... [[1, -1, -1, 2]]
- AddV2: 2x
- Cast: 2x
- Pack: 1x
TRTEngineOp_000_004 device:GPU:0 5 4 1 ['float16', 'f ... ['float32'] [[1, -1, 1], [ ... [[1, -1, -1, 2]]
- AddV2: 2x
- Cast: 2x
- Pack: 1x
TRTEngineOp_000_005 device:GPU:0 5 4 1 ['float16', 'f ... ['float32'] [[1, -1, 1], [ ... [[1, -1, -1, 2]]
- AddV2: 2x
- Cast: 2x
- Pack: 1x
TRTEngineOp_000_006 device:GPU:0 5 2 1 ['int32', 'int32'] ['int32'] [[-1, 1], [-1, 1]] [[-1, 2, 2]]
- Const: 2x
- Mul: 2x
- Pack: 1x
TRTEngineOp_000_007 device:GPU:0 5 2 1 ['int32', 'int32'] ['int32'] [[-1, 1], [-1, 1]] [[-1, 3, 2]]
- Const: 2x
- Mul: 2x
- Pack: 1x
TRTEngineOp_000_008 device:GPU:0 5 2 1 ['int32', 'int32'] ['int32'] [[-1, 1], [-1, 1]] [[-1, 3, 2]]
- Const: 2x
- Mul: 2x
- Pack: 1x
TRTEngineOp_000_009 device:GPU:0 5 2 1 ['int32', 'int32'] ['int32'] [[-1, 1], [-1, 1]] [[-1, 3, 2]]
- Const: 2x
- Mul: 2x
- Pack: 1x
TRTEngineOp_000_010 device:GPU:0 91 12 31 ['float32', 'i ... ['float32', 'f ... [[1, 3, 100], ... [[1, 100, 3], ...
- AddV2: 5x
- Cast: 1x
- Const: 14x
- FloorDiv: 12x
- Mul: 18x
- Pack: 1x
- Reshape: 16x
- StridedSlice: 1x
- Sub: 12x
- TopKV2: 1x
- Transpose: 10x
TRTEngineOp_000_011 device:GPU:0 29 10 10 ['float16', 'f ... ['float32', 'i ... [[1, 128, 128, ... [[1, 3, 100], ...
- Cast: 5x
- Const: 4x
- Mul: 5x
- Reshape: 5x
- TopKV2: 5x
- Transpose: 5x
TRTEngineOp_000_012 device:GPU:0 54 15 10 ['float16', 'f ... ['float32', 'f ... [[1, 300], [1, ... [[1, 3, 100, 2 ...
- AddV2: 10x
- Cast: 10x
- Const: 4x
- ExpandDims: 5x
- Pack: 5x
- Reshape: 5x
- Transpose: 10x
- Unpack: 5x
TRTEngineOp_000_013 device:GPU:0 790 3 24 ['float32', 'f ... ['float32', 'f ... [[1, 128, 1], ... [[1, 128, 128, ...
- Abs: 6x
- AddV2: 19x
- BiasAdd: 88x
- Const: 413x
- Conv2D: 96x
- ExpandDims: 1x
- FusedBatchNormV3: 56x
- MaxPool: 7x
- Mul: 2x
- Pad: 2x
- Relu: 70x
- ResizeNearestNeighbor: 3x
- Sigmoid: 6x
- StridedSlice: 15x
- Sub: 6x
TRTEngineOp_000_014 device:GPU:0 6 2 2 ['float32', 'f ... ['float32', 'f ... [[1, -1, 4], [ ... [[1, -1, 2, 4] ...
- Const: 2x
- ExpandDims: 2x
- Tile: 2x
TRTEngineOp_000_015 device:GPU:0 8 3 3 ['float32', 'f ... ['float32', 'f ... [[1, -1, 4], [ ... [[1, -1, 3, 4] ...
- Const: 2x
- ExpandDims: 3x
- Tile: 3x
TRTEngineOp_000_016 device:GPU:0 17 5 5 ['int32', 'int ... ['int32', 'int ... [[1, 100, 3], ... [[1, 100, 3], ...
- Const: 2x
- ExpandDims: 5x
- Sum: 5x
- Tile: 5x
TRTEngineOp_000_017 device:GPU:0 33 10 5 ['float32', 'f ... ['float32', 'f ... [[1, -1, 3, 2] ... [[1, -1, 100, ...
- Const: 3x
- ExpandDims: 5x
- Mul: 5x
- Sqrt: 5x
- Sub: 5x
- Sum: 5x
- Tile: 5x
TRTEngineOp_000_018 device:GPU:0 6 5 5 ['float32', 'f ... ['float32', 'f ... [[1, -1, 100, ... [[1, -1, 100, ...
- Const: 1x
- Mul: 5x
TRTEngineOp_000_019 device:GPU:0 21 20 5 ['float32', 'f ... ['float32', 'f ... [[1, -1, 3], [ ... [[1, -1, 3], [ ...
- Const: 1x
- Maximum: 5x
- Mul: 5x
- Sub: 10x
[*] Total number of TensorRT engines: 20
[*] % of OPs Converted: 52.99% [1134/2140]
2023-01-22 09:15:20.108012: I tensorflow/compiler/tf2tensorrt/common/utils.cc:104] Linked TensorRT version: 8.4.3
2023-01-22 09:15:20.108405: I tensorflow/compiler/tf2tensorrt/common/utils.cc:106] Loaded TensorRT version: 8.4.3
2023-01-22 09:15:23.640329: I tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:1330] [TF-TRT] Sparse compute capability: enabled.
2023-01-22 09:20:03.394695: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forTRTEngineOp_000_007 due to failure in verifying input shapes: Incorrect batch dimension, for TRTEngineOp_000_007: [[0,1], [0,1]]
2023-01-22 09:20:03.394812: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forTRTEngineOp_000_008 due to failure in verifying input shapes: Incorrect batch dimension, for TRTEngineOp_000_008: [[0,1], [0,1]]
2023-01-22 09:20:03.394919: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forTRTEngineOp_000_009 due to failure in verifying input shapes: Incorrect batch dimension, for TRTEngineOp_000_009: [[0,1], [0,1]]
2023-01-22 09:20:04.433500: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.433578: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for TRTEngineOp_000_002 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.433656: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:937] TF-TRT Warning: Engine retrieval for input shapes: [[1,0,1], [1,0,1], [1,0,3], [1,0,3]] failed. Running native segment for TRTEngineOp_000_002
2023-01-22 09:20:04.434333: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.434428: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for TRTEngineOp_000_003 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.434532: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:937] TF-TRT Warning: Engine retrieval for input shapes: [[1,0,1], [1,0,1], [1,0,3], [1,0,3]] failed. Running native segment for TRTEngineOp_000_003
2023-01-22 09:20:04.434842: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.434927: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for TRTEngineOp_000_004 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.435017: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:937] TF-TRT Warning: Engine retrieval for input shapes: [[1,0,1], [1,0,1], [1,0,3], [1,0,3]] failed. Running native segment for TRTEngineOp_000_004
2023-01-22 09:20:04.435190: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.435338: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for TRTEngineOp_000_005 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,1] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:04.435474: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:937] TF-TRT Warning: Engine retrieval for input shapes: [[1,0,1], [1,0,1], [1,0,2], [1,0,2]] failed. Running native segment for TRTEngineOp_000_005
2023-01-22 09:20:07.408563: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,3,2] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:07.408636: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:1104] TF-TRT Warning: Engine creation for TRTEngineOp_000_017 failed. The native segment will be used instead. Reason: UNIMPLEMENTED: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,3,2] is an empty tensor, which is not supported by TRT
2023-01-22 09:20:07.408681: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:937] TF-TRT Warning: Engine retrieval for input shapes: [[1,0,3,2], [1,0,3,2], [1,0,100,3,2], [1,0,2,2], [1,0,100,2,2], [1,10,2,2], [1,10,100,2,2], [1,0,3,2], [1,0,100,3,2], [1,0,100,3,2]] failed. Running native segment for TRTEngineOp_000_017
2023-01-22 09:20:07.424732: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,100,3] is an empty tensor, which is not supported by TRT
2023-01-22 09:21:05.886347: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,4] is an empty tensor, which is not supported by TRT
2023-01-22 09:21:05.887228: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,4] is an empty tensor, which is not supported by TRT
2023-01-22 09:21:06.891027: W tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:5927] TF-TRT Warning: Validation failed for TensorRTInputPH_0 and input slot 0: Input tensor with shape [1,0,3] is an empty tensor, which is not supported by TRT
2023-01-22 09:21:06.947776: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forTRTEngineOp_000_009 due to failure in verifying input shapes: Incorrect batch dimension, for TRTEngineOp_000_009: [[0,1], [0,1]]
2023-01-22 09:21:06.948063: W tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:847] TF-TRT Warning: Running native segment forTRTEngineOp_000_008 due to failure in verifying input shapes: Incorrect batch dimension, for TRTEngineOp_000_008: [[0,1], [0,1]]
Done Converting to TF-TRT FP16
- Inference image by convertied saved_model by following script.
This script runs successfly and gets ineference results, but I get warning and slow inerence.
import tensorflow as tf
from tensorflow.python.saved_model import signature_constants
import cv2
import numpy as np
image_file_path = '<image file path>'
MODEL_PATH = '<model path>'
m = tf.saved_model.load(MODEL_PATH)
ff = m.signatures[signature_constants.DEFAULT_SERVING_SIGNATURE_DEF_KEY]
img = cv2.imread(image_file_path).copy()
img = cv2.resize(img, dsize=(512,512))
img = cv2.cvtColor(img, cv2.COLOR_BGR2RGB)
input_tensor = img[tf.newaxis, ...].astype(np.uint8)
input_tensor = tf.convert_to_tensor(input_tensor)
results = ff(input_tensor)
print(results)
I’m struggling for solving this warning for over 2 weeks. Thanks.
