My usd_model cannot move normally after importing my URDF model into USD
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
[√] 4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
[√] Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 4090D
  • Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
I imported my URDF into a USD model. When I set a joint position target within the limit using set_joint_position_target, for example, 0.2, it would move rapidly and then fall apart. However, this USD model can run normally under the Gain-tuner test in IsaacSim.
Steps to Reproduce
my_model (2).zip (16.0 MB)
  1. inspire_hand_left_usd is my usd,
    inspire_hand_urdf is my raw urdf,
    test_run_articulation.py is my test python file
    inspire is my cfg
  2. After running test_run_articulation.py , the situation I mentioned will occur
    (Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
In my_model.zip,thanks
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
I have tried replacing the usd_path in cfg with allegro’hand and shadowhand from the official sample separately, but my own conversion of urdf does not work properly
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
This problem has been bothering me for a long time, and I am very grateful that you can solve it for me!!
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
