We’re preparing to use Orin with TensorRT8.3 for better performance, but it failed when creating a Builder. Error occurred in myelin which is close-sourced, we’ve gotten stuck here for days and had no clue where to start debugging, so ask for your help.
Please note that I am using orin, which only goes wrong at fp16, and int8 can pass normally.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
