Hi, I am working on deploying MobileNetv2 on Jetson Nano and am having trouble converting these networks from TensorflowV2.5.0 Object_detection_api to TensorRT. I tried to convert the .onnx model to TensorRT engine, but I get this Myelin error:
[06/21/2021-10:11:26] [V] [TRT] Formats and tactics selection completed in 157.841 seconds.
[06/21/2021-10:11:26] [V] [TRT] After reformat layers: 135 layers
[06/21/2021-10:11:26] [V] [TRT] Block size 16777216
[06/21/2021-10:11:26] [V] [TRT] Block size 8640000
[06/21/2021-10:11:26] [V] [TRT] Block size 3240448
[06/21/2021-10:11:26] [V] [TRT] Block size 1440256
[06/21/2021-10:11:26] [V] [TRT] Block size 540160
[06/21/2021-10:11:26] [V] [TRT] Block size 39424
[06/21/2021-10:11:26] [V] [TRT] Block size 7680
[06/21/2021-10:11:26] [V] [TRT] Block size 2048
[06/21/2021-10:11:26] [V] [TRT] Block size 1536
[06/21/2021-10:11:26] [V] [TRT] Block size 1024
[06/21/2021-10:11:26] [V] [TRT] Block size 512
[06/21/2021-10:11:26] [V] [TRT] Total Activation Memory: 30699008
[06/21/2021-10:11:26] [I] [TRT] Detected 1 inputs and 4 output network tensors.
[06/21/2021-10:11:26] [E] [TRT] ../builder/myelin/codeGenerator.cpp (112) - Myelin Error in addNodeToMyelinGraph: 0 (map/while/TensorArrayV2Read/TensorListGetItem operation not supported within a loop body.)
[06/21/2021-10:11:26] [V] [TRT] Builder timing cache: created 72 entries, 22 hit(s)
[06/21/2021-10:11:26] [E] Engine creation failed
[06/21/2021-10:11:26] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # trtexec --explicitBatch --onnx=/home/varya/weights/tf22/model_float_nms.onnx --verbose
Environment
TensorRT Version : 7.2
NVIDIA GPU : Jetson Nano L4T 32.4.3; nvidia-jetpack: 4.4.1
Python Version : 3.6
Tensorflow Version : 2.3.1+nv20.12
onnx : 1.9.0
tensorflow-onnx : 1.9.0
onnx-graphsurgeon : 0.3.7
Relevant Files
onnx models:
Steps To Reproduce
to convert I do the following:
- convert the save_model to .onnx file
tf2onnx.convert --saved-model /home/tf2/saved_model --output /home/tf2/model.onnx --opset 11
- change data type from uint8 to float32
import onnx
import numpy as np
import onnx_graphsurgeon as gs
graph = gs.import_onnx(onnx.load("/home/tf2/model.onnx"))
for inp in graph.inputs:
inp.dtype = np.float32
onnx.save(gs.export_onnx(graph), "/home/tf2/model_float.onnx")
- replace NMS using the BatchedNMSDynamic_TRT plugin
import onnx
import numpy as np
print ("Running BatchedNMSDynamic_TRT plugin the ONNX model.. ")
input_model_path = "/home/tf2/model_float.onnx"
output_model_path = "/home/tf2/model_nms.onnx"
def replace_nms(graph, boxes, scores, nms_out):
scores.outputs.clear()
nms_out.inputs.clear()
nms_attrs = {'shareLocation': True,
'backgroundLabelId': -1,
'numClasses': 4,
'topK': 20,
'keepTopK': 20,
'scoreThreshold': 0.3,
'iouThreshold': 0.6,
'isNormalized': True,
'clipBoxes': True}
nms_num_detections = gs.Variable(name="nms_num_detections", dtype=np.int32, shape=(1, 1))
nms_boxes = gs.Variable(name="nms_boxes", dtype=np.float32, shape=(1, 20, 4))
nms_scores = gs.Variable(name="nms_scores", dtype=np.float32, shape=(1, 20))
nms_classes = gs.Variable(name="nms_classes", dtype=np.float32, shape=(1, 20))
boxes_reshaped = gs.Variable(name="boxes_reshaped", dtype=np.float32, shape=(1, -1, 1, 4))
boxes_shape = gs.Constant(name="boxes_shape", values=np.array([1, -1, 1, 4], dtype=np.int32))
reshape = gs.Node(op="Reshape", inputs=[boxes, boxes_shape], outputs=[boxes_reshaped])
graph.nodes.append(reshape)
node = gs.Node(op="BatchedNMSDynamic_TRT", attrs=nms_attrs,
inputs=[reshape.outputs[0], scores], outputs=[nms_num_detections, nms_boxes, nms_scores, nms_classes])
graph.nodes.append(node)
graph.outputs = [nms_num_detections, nms_boxes, nms_scores, nms_classes]
return graph
graph = gs.import_onnx(onnx.load(input_model_path))
graph.inputs[0].shape=[1,300,300,3]
tmap = graph.tensors()
boxes, scores, nms_out = tmap["Unsqueeze__568:0"], tmap["Unsqueeze__671:0"], tmap["NonMaxSuppression__673:0"]
boxes.outputs.clear()
graph = replace_nms(graph, boxes, scores, nms_out)
scores, nms_out = tmap["Unsqueeze__637:0"], tmap["NonMaxSuppression__639:0"]
scores, nms_out = tmap["Unsqueeze__603:0"], tmap["NonMaxSuppression__605:0"]
scores, nms_out = tmap["Unsqueeze__569:0"], tmap["NonMaxSuppression__571:0"]
graph.cleanup()
graph.toposort()
onnx.save_model(gs.export_onnx(graph), output_model_path)
- convert to TRT
trtexec --explicitBatch --onnx=/home/tf2/model_nms.onnx --verbose
