"N: Skipping acquire of configured file..." warnings when run `sudo apt update`
Hallo all,
Device: Jetson Nano 4GB
OS: Ubuntu 18.04LTS (JetCard: JetPack 4.5.1)
Command:
$ sudo apt update
Output:
Get:1 file:/var/cuda-repo-l4t-10-2-local  InRelease
Ign:1 file:/var/cuda-repo-l4t-10-2-local  InRelease
Get:2 file:/var/visionworks-repo  InRelease
Ign:2 file:/var/visionworks-repo  InRelease
Get:3 file:/var/visionworks-sfm-repo  InRelease
Ign:3 file:/var/visionworks-sfm-repo  InRelease
Get:4 file:/var/visionworks-tracking-repo  InRelease
Ign:4 file:/var/visionworks-tracking-repo  InRelease
Get:5 file:/var/cuda-repo-l4t-10-2-local  Release [564 B]
Get:6 file:/var/visionworks-repo  Release [2.001 B]
Get:7 file:/var/visionworks-sfm-repo  Release [2.005 B]
Get:8 file:/var/visionworks-tracking-repo  Release [2.010 B]
Hit:9 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease
Get:11 https://repo.download.nvidia.com/jetson/common r32.6 InRelease [2.555 B]
Hit:12 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease
Hit:13 https://repo.download.nvidia.com/jetson/t210 r32.6 InRelease
Hit:14 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease
Hit:16 http://packages.ros.org/ros/ubuntu bionic InRelease
Fetched 2.555 B in 3s (871 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'restricted/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'universe/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'multiverse/binary-aarch64/Packages' as repository 'http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease' doesn't support architecture 'aarch64'
N: Skipping acquire of configured file 'main/binary-aarch64/Packages' as repository 'http://packages.ros.org/ros/ubuntu bionic InRelease' doesn't support architecture 'aarch64'
Because the package list is not getting updated, I’m unable to install any package from the repository. It’s strange that it says bionic InRelease' doesn't support architecture 'aarch64'. I wasn’t even able find some reasonable info on this online, so any help to get rid of these warnings is appreciated. If anymore information is required, I’m happy to coordinate.
Thank you very much.
hello Jayadev,
may I know what’s the source configuration, nvidia-l4t-apt-source.list.
did you revise the repo to point to r32.6 release?
