namd compiling error
Dear all:
I was trying to compile the NAMD2.7b1 version on a CRAY-XT3 supercomputer, and get the following error that I do not understand.
PGCC-W-0277-Cannot inline function _mm_set_pd - data type mismatch (/opt/pgi/8.0.4/linux86-64/8.0-4/include/CC/iostream: 882)
PGCC-W-0277-Cannot inline function _mm_set_pd - data type mismatch (/opt/pgi/8.0.4/linux86-64/8.0-4/include/CC/iostream: 883)
PGCC-W-0277-Cannot inline function _mm_set_pd - data type mismatch (/opt/pgi/8.0.4/linux86-64/8.0-4/include/CC/iostream: 884)
Does this look familiar to you guys? Any idea what would be the problem?
Thanks a lot.
Bin
Hi Bin,
This is just a warning, not an error, so most likely can be ignored. To check, I downloaded and compiled NAMD2.7b1 but didn’t see the warning. Can you post the full compilation line which emits this warning? Which configuration are you using?
Thanks,
  • Mat
