Nano 2GB no longer starts up?
Hi, I have been using my Nano 2GB for approximately 2 weeks, have been able to successfully access it either using an attached monitor or headlessly through SSH over WiFi, but found yesterday that I no longer could SSH into it. After attaching a monitor to the device and watching it start up, I see the following screen, then the device no longer seems to respond.
For reference, I have been using a CSI camera, and it was attached to the Nano during this start-up attempt. I have had the camera attached when booting up previously with no trouble, but this was the first re-boot after re-attaching it.
Should I be waiting longer for it to boot up? Re-flash system?
Thank you
hello nsk367,
this part of kernel logs seems it’s already enter linux kernel and it should able to use when boot-up complete. does it just hang there without response if you kept waiting?
please setup serial console and gather the complete boot logs.
you may refer to Jetson Nano - UART - JetsonHacks to setup the communication.
Yes, it hangs there with no real update after at least 10 minutes. The screen is black, and via ssh I receive the following:
port 22: Operation timed out
I’ll investigate the link you sent, but do you think re-flashing the entire device would work? (although it would mean losing anything saved exclusively to the device)
Thank you :-)
hello nsk367,
yes, it looks your hardware still functional, it should works after you re-flash the device completely.
