I am trying to attach custom metadata “unsigned int kitty” to the _NvOSD_RectParams. For this, I have modified the “nvll_osd_struct.h” like this:
typedef struct _NvOSD_RectParams {
unsigned int height; /**< Holds height of the box in pixels. */
unsigned int kitty; // Custom metadata
} NvOSD_RectParams;
And added this metadata to the “gstdsexample.cpp”
static void
attach_metadata_object (GstDsExample * dsexample, NvDsObjectMeta * obj_meta,
DsExampleOutput * output)
if (output->numObjects == 0)
return;
NvDsBatchMeta *batch_meta = obj_meta->base_meta.batch_meta;
NvDsClassifierMeta *classifier_meta =
nvds_acquire_classifier_meta_from_pool (batch_meta);
classifier_meta->unique_component_id = dsexample->unique_id;
NvDsLabelInfo *label_info =
nvds_acquire_label_info_meta_from_pool (batch_meta);
g_strlcpy (label_info->result_label, output->object[0].label, MAX_LABEL_SIZE);
nvds_add_label_info_meta_to_classifier(classifier_meta, label_info);
nvds_add_classifier_meta_to_object (obj_meta, classifier_meta);
nvds_acquire_meta_lock (batch_meta);
NvOSD_TextParams & text_params = obj_meta->text_params;
NvOSD_RectParams & rect_params = obj_meta->rect_params;
rect_params.kitty = (int)50; // modified custom metadata value
nvds_release_meta_lock (batch_meta);
Finally I wanted to read the metadata from deepstream_test3_app. For this, I have added the dsexample to the pipeline:
gboolean fullFrame = FALSE;
dsExample = gst_element_factory_make ("dsexample", "deepstream-example");
g_object_set (G_OBJECT (dsExample), "full-frame", fullFrame, NULL);
gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, dsExample, nvosd, transform, sink,
NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, dsExample, nvosd, transform, sink,
NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
But when I read the custom metadata value from a probe:
static GstPadProbeReturn
tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
//NvDsDisplayMeta *display_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
//int offset = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
int kitti = obj_meta->rect_params.kitty;
printf(" Custom Object meta:: kitty = %d\n", kitti);
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d\n",
frame_meta->frame_num, num_rects, vehicle_count, person_count);
return GST_PAD_PROBE_OK;
It was expected to get the value 50 on output, But its getting a value 3 here.
Custom Object meta:: kitty = 3 // Expected 50
Frame Number = 36 Number of objects = 4 Vehicle Count = 4 Person Count = 0
I just wanted to know of the method is correct or anything I am missing?
