Hi, I’m using devkit board to test but the nano boot always stuck in the same stage, and here is the boot log. nanolog.txt (24.3 KB)
It’s very strange that this module works fine in our custom board. And after I reflash it, it still boot stuck.
I used another devkit board it comes same result.
But months ago, these devkit board just works fine
Okay, I just found it maybe the power supply issue.
I use usb-hub to micro-usb to power the board, and when I change the connection by using micro-usb to a usb port, the board can boot normally.
But in dmesg, it shows a lot of printf like this
soctherm: OC ALARM 0X00000001
I wonder if this shows the micro usb power supply is not stable
Is the issue happening after you switch the new power supply?
If so, could you share the detail of your power supply before and after you hit the issue.
Is your micro-USB conneted on 5V/2A or 5V/4A adapter?
Before,I used micro-usb to a usb-hub to power up the devkit board and it will shutdown halfway. After I used micro-usb to a PC usb port and it can power up normally but with OC ALARM
No, I mean if the module set on our custom board to boot up. there is no OC ALARM
Hi, 5V/2A is the least requirement for USB port power supply. Please use the power source with 2A capability. And also please measure the power voltage level on carrier board to make sure it is correct 5V on board.
