A01 Carrier board
Delta 5V 6A medical grade power supply, no load at 5.2V, with load = 5.05V
few day prior the barrel jack was able to power the board, now i dont see the indicator or any power when utilize the barrel jack, however, without the jumper and micro-USB it is able to power up
while measuring the U58/TPS25944L, Vin does how 5.05v, but Vout is 0v
some components are missing around U58, as result i cant use the barrel jack for power, can you provide solution to bypass the U58? or just the schematic around that area
